20 Most Recent
Pen Drive IVO MP3 Player Questions & Answers
When I copy data to
Try to format the drive using FAT32 instead of NTFS just to check compatibility issue. It it doesn't work then maybe the pen drive is faulty.
Formatting will erase all data on this disk. to
Hi there
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Ntn showing
hey priya please tell me your problem i will give u suggestion
I want to format my
If you have a Windows based computer click on the start menu, then my computer, select the drive from the removable devices section, right click on the drive, select format, then quick format and start. If that doesn't work then left click (double clicking) on the drive and open a folder, once opened drag the mouse over all files to highlight them. Once highlighted press control+Delete on your keyboad and that should remove the files and wipe the drive..
I am not able to format my pen drive
Easiest way to format it is by connecting to the USB port of a PC . Click my computer / identify your Pen drive / right click on the drive - in the drop down Menu one of the options will be format. Click on format and it will warn you that you will loose all data / click yes and it will take about half a minute.
That's it.
When i insert my pendrive
click
right button on my computer then click manage then device manager .
After that double click diskdrives on the right pane and select your
pendrive and click enable on the toolber.show this image
My pen drive is detecting
Hey Anui kr59,
There is a chance it is trying to use a drive letter that is already in use. For example, if you plug it in the first time and it displays as your "k drive" and then you unplug it. Then you plug in a friend's thumb drive, it takes the "K Drive" title, and then you plug in yours again it will not be able to use the K drive.
In order to check/fix right click on my computer on the desktop. Go to "Manage". On the left side of the Computer Management window click on Disk Management (under Storage). Then right click on the name of your pen drive (typically called the manufacturer's name, default, or removable media). Click on change drive letter and paths. Then click Change, and choose a drive letter that is not currently in use, maybe the R drive. Press OK twice to return to the computer management window, press the X, and you should be back at the desk top and able to access your pen drive.
My 8gb hp pen drive
First of all and if you haven't done so already, restart your computer. If this does not resolve the issue, try right-clicking on the flash drive in the "My Computer" menu. If "Format..." is available as an option, select this and go through the process of formatting the device. Be aware that this will erase all data that you have saved on the drive.
Hp 4 gb pendrive not detected in mysystem
Try using it in other systems. You can try to reformat it per your user guide, but if it's not detected at all you probably won't be able to. If you can't format it, see it, or access it, then it's toast.
I own kingston 2gb pendrive.recently it got
Try deleting the virus and the files this way...just be sure not to delete the operating files to operate the pendrive:
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
