20 Most Recent SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Questions & Answers
2answers
Transfer pictures
1. Insert your sandisk drive intor the usb connector 2. browse the pictures you want to transfer 3. select the pictures (multiple select by holding Ctrl and clicking the picture or select pictures one-by one) 4. after selecting the pictures right click on them and select "Copy" (or your can just press Ctrl+C) 5. go to "My Computer" and browse your USB stick 6. right click and select "Paste" (or you can press Ctrl+V)
3/18/2020 6:34:22 AM • SanDisk Cruzer... • Answered on Mar 18, 2020
2answers
How to transfer computer pics to flash drive
Quite easy to transfer computer pics to flash drive via Windows Explorer: 1. Plug USB flash drive and iPhone to computer. iPhone will receive a prompt to approve it. Approve it and iPhone will be automatically detected by computer. 2. Open Windows Explorer and head to "iPhone > Internal Storage > DCIM". A list of photos on iPhone will show up. 3. Hold "Ctrl" and select photos you would like to transfer to USB stick and press "Ctrl + C". 4. Create a new folder in USB drive or find a folder, then press "Ctrl + V" to transfer iPhone photos to USB flash drive. windows explorer-undefined-undefined-0_0.jpg If you're prone to find more effective ways to transfer computer pics to flash drive, just check out this tutorial: https://www.leawo.org/tutorial/how-to-transfer-photos-from-iphone-to-usb-flash-drive-1361.html?=1400
1/16/2020 3:38:02 AM • SanDisk Cruzer... • Answered on Jan 16, 2020
2answers
How to get the pc games to the removable disc(J)
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
3/28/2019 8:48:44 AM • SanDisk Cruzer... • Answered on Mar 28, 2019
2answers
MY 8GB SANDISK CRUIZER MICRO
It has an internal failure. Either bad solder or a bad chip. This is not a user repairable device. Your best bet at this point is a data recovery service.
10/21/2018 1:21:41 AM • SanDisk Cruzer... • Answered on Oct 21, 2018
3answers
Outlook Mail problem
you can find the following details on the site at the below url
http://www.ghacks.net/2009/03/14/hotmail-pop3-configuration/
Here are the information that have to be entered into the desktop email software so that Hotmail can be accessed:
  • Incoming Server: pop3.live.com
  • Incoming Port: 995
  • SSL Encryption: yes
  • Outgoing Server: smtp.live.com
  • Outgoing port: 25 (use port 587 if the default port is not working)
  • Authentication: yes
  • TLS Or SSL: yes
Please note that the names might differ depending on the desktop email client in use. The values on the other hand do not change. The username (usually the Windows Live Hotmail email address) and password are the same that are used when logging into the Hotmail website using a web browser.
There is no need for configuration of POP3 on the Hotmail website. wpsf-img.php google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
8/18/2018 8:24:56 AM • SanDisk Cruzer... • Answered on Aug 18, 2018
Retrieve photos from sandisk 2.0 having forgotten password
Short answer is you can't. Its encrypted. If you could bypass the PW, it would not be very useful for protection. you may be able to format and use it as new, but not access the content on it currently at all.
5/10/2018 4:13:13 PM • SanDisk Cruzer... • Answered on May 10, 2018
3answers
How do i remove write-protection from my cruzer edge flash drive
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if
you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the security tab option then advanced make sure you have full control in windows 7
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps you
3/20/2018 10:13:47 AM • SanDisk Cruzer... • Answered on Mar 20, 2018
Can't format a flash (thumb USB) Drive on my
Download Partition Wizard for mac bootable version and burn it to a dvd. Now, put the dvd in and turn off the computer, now put the usb drive in. Start the computer and boot from dvd drive Partition Wizard will boot up, left click on the usb drive and of the left side click format, now up top left click apply. Wait until it's done, now your usb drive is blank.
10/17/2017 1:54:04 PM • SanDisk Cruzer... • Answered on Oct 17, 2017
When I insert sandisk cruzer
Since it works with other systems there is a system incompatibility issue. Are you using the same OS in this machine as in the others where it works? Could it be that? Using XP? It has some issues with some usb devices.
9/24/2017 1:47:17 AM • SanDisk Cruzer... • Answered on Sep 24, 2017
2answers
My 8gb pendrive is showing
You should format it through DOS...rate my answer
11/10/2015 1:43:43 AM • SanDisk Cruzer... • Answered on Nov 10, 2015
7answers
How can I recover a deleted file on my Cruzer USB
if you have choosen only delete option then you can restore it from recycle bin but in most cases the deleted files from usb drive does not go into recycle bin, rather they are pemanently deleted. if you have choosen shift+delete then there is no way that you can get the file back as shift+delete permanently deletes the files..
8/25/2015 9:14:26 AM • SanDisk Cruzer... • Answered on Aug 25, 2015
How to copy file before format a pen drive?
Open My Computer and copy the file from your flash drive to your computers hard drive (C:\...).
11/26/2014 9:22:52 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
I want to delete what I have on there to make room for other stuff
If you want to completely wipe it clean, format it. Otherwise, open the drive in My Computer and delete specific files as you wish.
11/26/2014 9:07:42 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
How do I download word documents to cruzer flash drive
From Word, use Save As.... and point the file to your USB drive. You can also open two instances of My Computer and drag & drop from the PC to the flash drive.
11/26/2014 8:33:54 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
My laptop is not able to detect sandisk cruzer blade (8gb) but my friend's laptop and my desktop detects it.
Your laptop may need drivers installed for your flash drive. Visit your USB drive manufacturer's website, find the "Support" page, and download the drivers for your specific drive. Be sure to know what version of your operating system you are running as it may be necessary to ensure you get compatible drivers. Install the drivers and try again.
11/26/2014 8:31:30 PM • SanDisk Cruzer... • Answered on Nov 26, 2014
8answers
How to recover data from SanDisk cruzer micro 8GB U3 launchpad?
My Micro Sandisk Cruzer USB U3 (16GB) indicates the error the disk in drive I is not formatted, Do you want to format it now? How do you resolve this without reformatting and lost of data?
9/4/2014 11:51:51 AM • SanDisk Cruzer... • Answered on Sep 04, 2014
Unable format
What software are you using to attempt formatting? You should be using the special software available from the card maker.
6/22/2014 8:44:58 AM • SanDisk Cruzer... • Answered on Jun 22, 2014
WHAT PROBLEM ARE U FACING? KINDLY EXPLAIN IT CLEARLY! http://www.tinyurl.com/9307740
5/15/2014 7:22:08 AM • SanDisk Cruzer... • Answered on May 15, 2014
Remove write protection
This could be a Windows Registry setting that disables you from writing to your flash drive (or formatting it). If you are running Windows after Win XP SP2, you can change that setting. To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>. 2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies. 3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled). 4.Close the registry editor and restart Windows. 5.After Windows starts, test writing to your USB drive. Important Note: Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored. For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
4/29/2014 8:15:50 PM • SanDisk Cruzer... • Answered on Apr 29, 2014
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
391 questions posted
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
Cruzer SanDisk
  • Cruzer SanDisk
Most Popular Question
recover deleted file cruzer usb
  • Electronics - Others
