Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Anonymous Posted on Apr 29, 2008
3 INCHES HORIZONTAL LINES ON SCREEN
  1. WHITE LINES APPEAR ON RIGHT SIDE OF THE SCREEN (HORIZONTAL LINES) LIKE A HORIZONTAL RINGING BARS
  • 1 more comment
  • lcdproblems Apr 29, 2008
    i have a 26 inch lcd from maxent that is starting to show a weird color band on the left edge of the screen. it is a 5 inch long band ring shaped and displays incorrect color. anyone knows what is wrong?
  • Anonymous May 11, 2010
    so far i cant fix the problem,am looking for aservice manual of this plasma tv, technically my experienced about this problem is the coupling capacitor but for this kind of symtons am just want to make sure, if i could adjust this horizontal through remote ctl. or service mode of this model.PD32-A3000. if anyone have this manual of hitachi, let me know and highly appreciate.thanks
  • Anonymous Mar 25, 2014
    Good picture but has horizontal line looks like ink smudge
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5157
Points
11
I have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Anonymous
Level 1:
New Friend:
  • Posted on Aug 07, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5157
Points
Hp 7540 crd moniter
HORIZONTAL LINES ON SCREEN issuse
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I am using the Asus VH236H for video game playing on my playstation 3 and xbox 360. I was playing marvel vs capcom 3 last night and notice a red vertical bar appear on the left hand side of the screen and...
Flat monitors work on a grid method, if one of the grid is failing it creates a horizontal or verical line. its not something you can fix, so send it back.
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
4answers
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
3helpful
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
KDF-E50A10 Sony TV Purchased May 06
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
