20 Most Recent
HTC TYTN GSM Phone Questions & Answers
Can't send picture messages
Make sure that your mms is set to t-mobile:
http://216.155.174.84/servlets/MMS
Also make sure to have T-Mobile Data set to:
APN: epc.tmobile.com
DNS: 66.94.9.120
ALT DNS: 66.94.25.120
Do not check the proxy check box.
I have a problem in
By providing your HTC Herm 200 15 digit IMEI number to HTC Customer Care (located on the back of your phone behind the battery) they will, within 5-10 Minutes of completing your payment, send you the an unlock code & instructions to instantly Unlock HTC Herm 200. Using your phone's keypad dial in the code provided, just like you would a phone number, et voila ! your HTC Herm 200 is unlocked for life and will work with any GSM carrier worldwide.
Thanks,
Vinay
HTC 8100 Locked
yes we can unlock u just join me on yahoo massanger : cellularhut_rajan
9810720720
I have htc tytn, when I turned on my screen is white
Good day
the white screen on your phone indicates that the screen on your phone is bad,and the only solution is to replace the screen of the phone,
The replacement of the htc tytn screen demands the physical approach of a highly skilled phone technician close to you to help you with the replacement of the screen.
Good luck!!!!
I have HTC herm200. When i connect to my Pc and do
Dear when you copy file to mobile go to programs and then File Explorer.
Look at left you will find My music or my documents or my pictures you just go my documents and find the files where you have copied
Htc herm200 can't charge
Hold down the two soft-keys (the ones below the screen) and while
you have them held down you poke the reset button with your stylus.
You'll then see a message on the screen saying 'press R to reset, X to
exit'. Pressing the R key on the keyboard will hard-reset the device.
It'll now take a few minutes to reboot and load all of the operator
customisation etc.
This procedure will hard reset the HTC TyTN, Vodofone v1605 and all other HTC Hermes variants.
I need to unlock my blackberry 8700g from t-mobile
you can do it on ebay. put unlock blackberry 8700g and you will find an unlocker. just pay and give them the IMEI number you will receive the unlock code by email and the instruction how to enter it. good luck
I start my herm200 only htc logo comes to screen,
..switch on and try hardreset :
Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
here also with some pictures:
http://www.hardreset.eu/htc_tytn_hermes_hard_reset_soft_reset_en.html
I cant go beyond the red green blue white screem
Everytime I turn on my phone its like that.
Nothing's wrong with your phone dear.
If you think Im not sure well I have the same phone and I've had it for a year. So Im sure nothings wrong. As long as its operating fine its ok. Believe me.
Just a little check...
Can you still use the camara?
Can you beam a photo to another phone using bluetooth? If yes, than NOTHING is wrong.
If you have anymore questions I'll be glad to help. Just comment back and I'll try to answer you ASAP.
Good Luck!
