20 Most Recent Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Questions & Answers
It is an attempt to get people to post a question here and hopefully get help--it also generates hits for the site--
When searching try to word the search to avoid what you do not want--some will Google looking for a owner manual when should Google with model number and just "manual".
There are other forums on the net but it can take time when searching to use the right keywords(search engines will find this site as it keys on many specific words).
As an expert who answers questions here (average of 300 a week for free) the other side of the coin is many post questions here with little or no basic information--brand-model number--clear description etc.
I had someone looking here and over the entire internet for a owner manual or explanation of why remote and keys on set would not function--no brand or model--when asked told me had manual but nothing in there helped--took a few minutes to locate that owner manual and on page 29 was the info he needed---told him and also commented nicely--if all else fails read the manual.
Reply within minutes was--OPPs and thanks--problem resolved.
Not all problems can be solved or answered depending on equipment or number of experts available.
If you have a TV with a problem feel free to post it here Attention
SD TECH with brand,model and as good a description as possible and I will attempt to help.
SD TECH
Sony BRAVIA... | Answered on Nov 30, 2018
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Sony BRAVIA... | Answered on Aug 20, 2018
The finger below is pointing to the HDMI ports.
hqdefault.jpgIf your TV doesn't have these ports then you don't have the ports available.
Sony BRAVIA... | Answered on Jan 29, 2018
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Sony BRAVIA... | Answered on Dec 19, 2017
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Sony BRAVIA... | Answered on Jun 19, 2017
The power supply is failing.
Sony BRAVIA... | Answered on Apr 17, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Sony BRAVIA... | Answered on Mar 28, 2017
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Sony BRAVIA... | Answered on Mar 24, 2017
Crack open your power supply again and take a look to make sure all caps are intact and not blown or bulging. Next check the main board for any possible caps and resistors, not likely as there is an external ps but possible. If you don't see anything odd then there may be an issue with the controller chip in which case you could replace but it would probably work out to the same price as buyin a new tv
Sony BRAVIA... | Answered on Oct 01, 2016
Probably in the menu settings if there isn't one on the remote
Sony BRAVIA... | Answered on Jul 30, 2016
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sony BRAVIA... | Answered on Jul 17, 2016
It cannot install.you only need a flash disk and load it with the fimware and nothing else inside.
Sony BRAVIA... | Answered on May 05, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Firmware (Software) update procedure to many popular brand TVs and other devices are given in detail.
Sony BRAVIA... | Answered on Mar 01, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Sony BRAVIA... | Answered on Jan 02, 2016
If you have dropped some food crumbs in there or dryed up coffee??...it might have stopped pressing on the PCB board..
open the case carefully with screw driver....
you may have to break a glue bond to...
clean the insides carefully and put back together.
Sony BRAVIA... | Answered on Sep 10, 2015
I plugged this code in and it worked:
10000
Good Luck
Sony BRAVIA... | Answered on Sep 03, 2015
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
370 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony bravia kdl 32m3000 sound no
  • Televison & Video
