SOURCE: Unit will not boot past Magellan splash screen
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and see if it did is firmware update,if not do it over and the unit plugged in with powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .for the sd card make sure is a flash sd card.i have a mastreo 4000 with a 2gb sd flashcard and it has no problem.theses units has unlimited amount of any size of gb sd flash card.let me know what happens.
SOURCE: Magellan Roadmate 360?
You can download the latest firmware here:
http://www.magellangps.com/support/notes.asp?supportID=290
It looks like your right, and it is no longer supported..
perhaps with the Magellan RoadMate PC application, there may be additional download available...
SOURCE: Need to update the maps
I need to update the map on my 3225 Magellan Maestro, can anyone help?
SOURCE: My magellan GPS Roadmate 1400 hard reset
there is a little pin hole on the side on the unit. you need a paper clip to reset it
SOURCE: Maestro 3250 Stuck on Magellan Screen at Start Up
go HERE, he/i will tell you how you can get it repaired free. this can be fixed but it requires a lot of time and patients..
i dont think there is enough space here to explain fully how to restore the gps....you cant make it any worst but why waste your time if you can get it done for free.
Testimonial: "Bill....you are great. I give you a 5 thumbs up. Very heplful."
