Hello, My M-Audio microtrack 24/96 battery runs
Similar problem to mine, and until I get my question answered, I can only propose a temporary solution.
Get a USB cable that fits the bottom small USB socket on your M-Audio Microtrack, but with a standard USB plug on the other end. Such a cable should have come with your Microtrack to begin with.
Replacement cables can be found at Best Buy, Radio Shack or most electronics stores or department stores. If the original cable is broken, please save it for reference to make sure you are getting the exact same type connectors when getting your replacement.
As I learned the hard way, not all small USB connectors are the same size, but APPEAR the same.
So, what are you connecting on the standard USB end?
A battery.
That's right, a rechargeable battery that features a power-only 5 volt USB receptacle. This will function as your A/C power adaptor does, only on the go.
The external rechargeable battery I use is a Black and Decker "Power to Go" unit that measures approx. 5 1/2"L X 3"W X 1" D.
It has both a low-draw two-prong AC (yes, it has an inverter and I never use it) and the desired 5V USB receptacle. You may find a better solution WITHOUT that A/C inverter. Just ask around for a rechargeable NmHh (better than NiCad) battery with a standard USB receptacle.
If the Microtrack's power is off when it is connected to the 5V power source (be it A/C power adaptor OR my proposed external battery), it will go into charge mode. With a fair amount of charge, remove the external power, and it boots up into operation. Then, re-connect the external power and your Microtrack is running and recording for a considerable longer time, depending on the charge and condition of your external battery.
Now, if one observes the LCD screen while running off of external power, the upper right corner box indicating the internal battery's charge shows "CHG" instead of the black square (Full charge) or half of the box in the form of a triagle (half charge) or any variation thereof as normaly indicated.
Someone might say, "But I don't want to have to carry around all this extra stuff! I want my old battery life back!"
Well, that's precisely how I feel as well.
But until you get your original lithium ion battery replaced (and at what cost for parts and labor?), you have to ask yourself if being an original condition purist is serving your situation well, or if this proposed add-on can get you by in the meantime.
Take care.
JJM
2/28/2011 1:19:24 PM •
M-Audio...
Answered
on Feb 28, 2011
