20 Most Recent Magellan Roadmate 1200 Car GPS Receiver Questions & Answers
I pressed Update OS (format
I have the same problem need help now please
6/21/2019 9:08:31 PM • Magellan... • Answered on Jun 21, 2019
2answers
Maps Updates
http://www.magellangps.com/products/software.asp
here you can find the updates...
4/12/2016 8:04:36 PM • Magellan... • Answered on Apr 12, 2016
3answers
Maps Updates
where can i go for updated free magellan1200 maps to update my gps
4/12/2016 8:04:02 PM • Magellan... • Answered on Apr 12, 2016
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
1/16/2015 7:00:36 PM • Magellan... • Answered on Jan 16, 2015
How to switch to canada region on magellan roadmate 1200
Just enter the address.
7/27/2014 8:33:03 PM • Magellan... • Answered on Jul 27, 2014
0answers
2answers
Magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
  1. Remove your SD card from your GPS
  2. Insert your SD card into an SD card reader or connect it to your PC
  3. Wait for windows to go through it's process of discovering your the "removable storage device" your just connected (see step 2)
  4. (This step may be different depending on what version of Windows you are using or depending on how you have your OS laid out). Look at the lower right hand corner of your desktop. There should me a small icon there with a green circle and a check mark. It looks like this...877f33f.jpg
  5. Click that with the right mouse button.
  6. It will say "Safely Remove Hardware" - Left click that message.
  7. A window will pop up allowing you to select your SD card and "Safely Remove" it (it will have a letter name like "drive F" for example).
  8. Wait for the windows to tell you it is ok to remove your hardware - then remove your SD card form the PC
  9. Make sure your GPS is turned off.
  10. Insert the SD card into your GPS.
  11. Turn on your GPS
  12. That's all! I hope I was able to help.
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
3/28/2014 2:43:21 PM • Magellan... • Answered on Mar 28, 2014
0answers
Language
Be the first to answer 3/13/2014 3:39:31 AM • Magellan... • Posted on Mar 13, 2014Be the first to answer
0answers
Not responding
Be the first to answer 1/20/2014 1:35:43 PM • Magellan... • Posted on Jan 20, 2014Be the first to answer
Yo quiero cambiar el idioma a espanol como puedo
Por favor, vaya a la página 84 de ESTE manual para cambiar sus ajustes de lengua S80.
Usted puede encontrar un eslabón para el manual a lo largo de w/otras telecargas, etc. para su NAVMAN AQUí.
Si este contesta que su pregunta para usted, por favor, toma sólo un momento para tasar mi solución - w/un "FixYa" sería más apreciado:)
1/16/2014 10:47:01 PM • Magellan... • Answered on Jan 16, 2014
I just got a Magellan
The USB must be for charging the unit and downloading updates when it becomes available. You have to unplug the USB and use the battery power to put in addresses .My 1200 does the same.
8/23/2013 4:55:58 AM • Magellan... • Answered on Aug 23, 2013
Magellan Roadmate 1200 Car GPS Receiver Logo
166 questions posted
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
View Most Popular
RoadMate Magellan
  • RoadMate Magellan
Most Popular Question
accidently erased everething
  • GPS
