20 Most Recent SanDisk Sansa e260 MP3 Player Questions & Answers
2answers
Retrieval of deleted voice recorded file
maybe, there are programs that retrieve deleted files, but sadly you need to buy them.
this only works if you havn't added any new voice recording (or a lot of voice recordings) or if you havn't reformatted your player.
8/29/2022 7:13:07 AM • SanDisk Sansa... • Answered on Aug 29, 2022
2answers
I cannot delete songs from Sansa E260
Ok, Sansa made it a little difficult this time,
"Connect your player, of course. Go to "My Computer" > "Sansa e260". There are hidden files. To unhide go to "Tools" (located on the menu bar) > "Folder Options..." > hit the "View" tab > select "Show hidden files and folders". You will see more folders to appear in a faded color. Click on the "MUSIC" folder. Click on the artist, then album then select the song, right click and down to delete." --Yahoo Answers
8/11/2022 9:09:05 PM • SanDisk Sansa... • Answered on Aug 11, 2022
2answers
Downloaded books from the library won't play
I was having the same problem when I used Overdrive Media Console to transfer my audiobook files to my Sansa. I updated the license and retransferred and even tried changing the USB settings on the mp2 player. What finally worked? Using Windows Media Player to sync the files instead. When I hooked up my Sansa I chose "use WMP to sync files" and then I dragged/dropped the audiobook files to the mediaplayer window. The audiobook now plays without any problems since WMP made sure the files have the latest subscription update code.
1/18/2022 3:03:37 AM • SanDisk Sansa... • Answered on Jan 18, 2022
2answers
Type of charger of Sansa
i have my SanDisk Sansa e260 MP3 Player and i lost my data cable, good thing is i have a spare of apple ipod charger, can i make use of it as data cable and how is it gonna be? thanks
9/29/2021 1:53:22 PM • SanDisk Sansa... • Answered on Sep 29, 2021
2answers
I have sansa e260v2 player.wat
AVI, MPEG-1/MPEG-2 in MPEG, MPG, MPE/VOB (unprotected), MPEG-4 in AVI format, DAT, ASF, QuickTime MOV (QuickTime 6.5 or higher required), WMV (Windows Media Player 9 or 10.0 required)
9/18/2021 3:09:52 AM • SanDisk Sansa... • Answered on Sep 18, 2021
2answers
I have the sana e260
the video is most likely in quicktime format. The sansa should play mp4 video which quicktime can create.
my only guess is the sansa software isn't that good anyway. You can try using a program like super or handbrake.
9/15/2021 3:15:32 AM • SanDisk Sansa... • Answered on Sep 15, 2021
2answers
Can't convert video
Hi
First in order to use the sandisk media converter your mp3 sansa should be recognized by your windows. You need to download MTP.
The new Media Transfer Protocol (MTP) enables you to manage content on any portable device with storag. Download from microsoft http://www.microsoft.com/downloads/details.aspx?familyid=a2e73160-e862-4f19-bb26-c0cafe798955&displaylang=en Once your sandisk is recognized then you can use the media converter. If you want to bypass media converter then you should buy a new media converter compatible with sandisk sansa and in this case you can convert without sandisk sansa attached to your computer. Please check it on the web. You can start by any video converter which available for free otherwise pro is a shareware: http://www.any-video-converter.com/products/for_video_free/
7/8/2021 4:36:44 AM • SanDisk Sansa... • Answered on Jul 08, 2021
2answers
I have a sansa e260r but i dont have a proper
You have to download a free program such as Riva FLV Encoder first, and use it to convert your Real/Winamp videos to AVI format. Once they are in AVI format, the Sansa Media Converter will recognize them.
-Tha Mp3 Doctor
7/8/2021 3:37:40 AM • SanDisk Sansa... • Answered on Jul 08, 2021
3answers
"Unknown" listed in spots for songs in player's list of all songs
You need to fix the id3 tags of songs. Just follow below steps to do that. ID3 is a metadata container most used on audio format, which provides audio data standard for music files, including Title, Artist, Year, Genre and other great information. And all ID3 tags are supported by most player software, like iTunes, and Windows Media Player. On Windows 10, music files have included metadata information like song name, artist name, or genre, but there will be times when this data may show up wrong or appear missing for a song or an entire album. To add tags to wav files, you can try Windows File Explorer. 1.Open the Windows File Explorer in your computer. (Windows key + E). 2.Browse the folder of the songs you want to add tags to wav files. 3.Right-click of the song, and then select "Properties". 4.Click to check the "Details" tab. It is well noted that all the details you see in the "Details" tab is part of the metadata information, and you can set wav ID3 tags by clicking the value field next to the property. 5.After updating the metadata information you like, click " Apply" and then "OK" button. With Windows File Explorer, it will also improve your file search function and you do not have to set it to icon or details mode in order to change the sort settings and then switch it back to preview mode. check-the- For more methods, check: Best 4 Methods: How to Edit Wav Tags
4/24/2020 1:47:16 AM • SanDisk Sansa... • Answered on Apr 24, 2020
2answers
Music problem
Edit the Id3 tags manually - takes time, but if you have THAT type of computer config, then there's just no other way.
4/24/2020 1:42:54 AM • SanDisk Sansa... • Answered on Apr 24, 2020
2answers
Dvd with usb port can not play avi
good day,
hope this link below will solve your problem.
nokia
2/21/2020 8:50:32 AM • SanDisk Sansa... • Answered on Feb 21, 2020
Odd song
I went to http://www.sandisk.com/Retail/Default.aspx?CatID=1468 and went to #2, watched the video and followed it.
4/24/2019 6:49:08 AM • SanDisk Sansa... • Answered on Apr 24, 2019
2answers
When I download music into my MP3 player I get
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover. Step 1. Run Tunes Cleaner and Scan Duplicate Songs After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs. Step 2. Add Music Files for Duplicates Removing You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add"button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing. Step 3. Start Deleting Duplicates After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs. For more details, check: How to Delete Duplicate Songs tunes-cleaner-scan-result-gwujvob1wsqcwi5j4bnkubbk-3-0_2.jpg
4/24/2019 6:32:39 AM • SanDisk Sansa... • Answered on Apr 24, 2019
2answers
Song Duplications
Do not syc with wmp. Drag and drop everything from windows explorer to the media folder on the sansa.........Format everything first ....Start over
4/22/2019 9:51:32 AM • SanDisk Sansa... • Answered on Apr 22, 2019
2answers
Tranfering video to device through video software
The Media Converter software will only recognize certain video types for conversion.
p.20 of manual:
Sansa Media Converter software lets you convert photos and videos as appropriate,
and then transfer them to your Sansa player. Sansa Media Converter offers
features such as cropping, rotating, and resizing before transferring them to your
player as well as the ability to transfer photo and video files to your microSD card.
Refer to the Sansa Media Converter software for file formats supported.
To transfer photos and videos to your Sansa player, follow these steps:
1. Connect the Sansa player to your computer.
2. Select Converter using Sansa Media Converter on initial connection.
3. Click Add Media to select photo or video files to be converted.
4. The Sansa Media Converter will store all converted files in My Album. Click
the Album Name box and type in the name you want.
5. Click to start the conversion process. A status box will appear
showing which file(s) are being converted.
12/26/2018 11:16:57 AM • SanDisk Sansa... • Answered on Dec 26, 2018
2answers
I want sandisk customer suppor centre in india
000-800-100-3277
[email protected]
M-F | 10:30am-7:30pm Local India time
9/13/2018 10:18:44 AM • SanDisk Sansa... • Answered on Sep 13, 2018
14answers
My mp3 player will not turn on, charge, or get detected by the computer. what do i do?
I saw it mentioned somewhere else....hold down the power button for about a minute. It should come back to life. It just worked for me, after I paniced a little, of course!
8/30/2018 4:17:42 PM • SanDisk Sansa... • Answered on Aug 30, 2018
0answers
0answers
SanDisk Sansa e260 MP3 Player Logo
2,568 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
restore pictures deleted from media go
  • Audio Players & Recorders
