Brother HL-2070N Printer Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the toner - Brother HL-2070N Printer
Anonymous
Level 2:
  • Expert 268 Answers
  • Posted on Aug 09, 2010
Anonymous
Expert
Level 2:
Answers
268
Questions
0
Helped
110381
Points
796
Follow this to the Brother site and follow the illustrated instructions. This shows how to change the drum unit.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000054/faq000154_014.html?reg=us&c=us&lang=en&prod=hl2070n_all&Cat=7
I hope this helps.
3helpful
How removed toner indication still toshiba copier e-studio-181?
toshiba e-studio 181 toner indication patmanent still.
tip
Drum needs to be replaced message,Remove waste toner,Waste toner full
Save money by removing your drum units waste toner yourself.By removing waste toner the drum life will be increased.Remove the waste toner every 3 to 5 thousand prints.
The main cause of drum failure in this model is caused by waste toner build up at the back of the drum,this cause the drum cleaning blade to put more pressure on the drum and.
Slide the platte-ned cover Assembly to the left open the left cover,remove the drum and developing Assembly like you do when you have to remove a paper jam.The drum and developer assy is attached by 2 blue clips,unlock the clips and separate the def and drum.On top of the drum unit the is a plastic plug that you can remove and trough out the toner in a dustbin with plastic bag coverd.Do not use this toner again in the machine.
Reinstall the plug and connect the drum and developer unit with the two clips.Reinstall the unit.
By removing the waste toner regally you will save on service cost as well.
18helpful
Sharp MX 2300N - Toner collection unit needs replacing, not sure what this means. We replaced toner cartridgers very recently and assume this is a container that collects loose toner particles. How do...
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
1helpful
2answers
11helpful
2answers
Remove all toner cartridges
It took me some time but I found the sollution:
Remove the powercord from the printer.
Open the front door and remove the first toner.
Close the front door and open the top door, remove the photo conductor.
When the front door is closed, you can turn the toner trommel and move it so that the second toner gets in the remove position.
Open the front door and remove the toner.
Close the front door and turn the trommel.
Repeat those steps until all are removed.
Cannot remove old cartridge
steps for removing and replacing the toner cartridges:
-before removing the toner cartridges, disconnect the A/C power cable from the back of the system & remove the printer's top cover
-rotate the securing lever upward to unlock the toner cartridge
-lift the cartridge out of the chassis, each toner housing and cartridge is color-coded and labeled for easy identification of toner cartridge color locations
-just reverse the previous steps to replace the toner cartridges
I have changed toner for copier NP-3050. Waste toner didn't remove. Is it necessary to remove the waste toner from the box ?
yes it's necessary to remove waste toner, because n long time the waste toner jamed the clining (I think in the 3050 the waster toner drop by a pipe inside the drum)
5helpful
Cannot remove toner cartridge
There is a manual removal option. Open the front cover. Then the top. Remove the drum. Close the front cover. (leave the top open). Move the toner housing unit so the required toner is accessable from the back. Remove.
Replace drum. Restart printer. The housing unit shoud rotate the empty spot to the front so you can insert the new toner.
Good luck.
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
7helpful
2answers
Hp 5550 dtn 10.00.00 supply memory erro
the chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
Norman Weimar
Norman Weimar
k24674
