20 Most Recent Brother HL-2070N Printer Questions & Answers
Uncheck grey scale in your printer properties.
Brother HL-2070N... | Answered on Feb 28, 2016
You can find step by step configuration from the below link:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000360/HL2070N_NUG_ENG_1.pdf
Please rate this, if you like soution
Thanks
Sandeep
Brother HL-2070N... | Answered on Mar 11, 2011
Follow this to the Brother site and follow the illustrated instructions. This shows how to change the drum unit.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000054/faq000154_014.html?reg=us&c=us&lang=en&prod=hl2070n_all&Cat=7
I hope this helps.
Brother HL-2070N... | Answered on Aug 09, 2010
Go to this guide on the Brother site and use the links there to correct the problem. it has illustrations that will help.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000006/faq000006_008.html?reg=us&c=us&lang=en&prod=hl2070n_all&Cat=112
I hope this helps.
Hi there
Some times it is because of a Virus on your pc.
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Brother HL-2070N... | Answered on Mar 21, 2010
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Brother HL-2070N... | Answered on Jan 21, 2010
Hello, Angie.
If there are no jobs in the queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, let us know if any error messages and please provide more details.
Hope that helps.
Brother HL-2070N... | Answered on Dec 13, 2009
ok so its not a new cartridge there for 2 options remain.
1) it needs chipping back to 0
meaning its been refilled without being reset.. the little chip on the side..
2) its a dud sorry to be blunt but ppl can and will sell anything on ebay,,
hope this helps you
Brother HL-2070N... | Answered on Sep 27, 2009
try the clean heads & there is a cleaner paper thats made to solve this issue.
Brother HL-2070N... | Answered on Aug 17, 2009
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Brother HL-2070N... | Answered on Jul 22, 2009
Tip
Paper jam
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path.
on Jun 03, 2009 | Brother HL-2070N Printer
reset by unplugging and then plugging back in, also make sure no paper is stuck in the rollers on top or the back....make sure all rollers are free of dust and if they have dust wipe off.....make sure you using the right type of paper and the printer itself isn't dirty....hope this helps
Brother HL-2070N... | Answered on Jun 03, 2009
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
Brother HL-2070N... | Answered on May 22, 2009
Try to reinstall the software and should be fine.
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
Brother HL-2070N... | Answered on May 12, 2009
gan mohon bantuan pencerahannya, di kantor saya memiliki printer LQ 2190 saat ini memiliki kendala lampu indikator merah nyala semua dan printer tidak bisa nge print, itu di sebabkan kenapa ya gan, dan bagaimana cara memperbaikinya
mohon bantuan pencerahannya ya gan
Brother HL... | Answered on Dec 07, 2017
Take it back for warranty, do not mess with it.
Brother HL... | Answered on Jun 27, 2017
Brother HL-2070N Printer Logo
21 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
line black line appears all prints
  • Office Equipment & Supplies
