This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
If it is then the answer is simply that you have not removed the transportation bolts/brackets that secure the drum in transit. Look at the manual - it will tell you how to do this.
If it's not a new machine then post here again and i will try to help further.
try to check for slackness when the tub is empty causing a rocking/slapping motion whilst empty. if the tub is used regularly and to its maximum capacity then the likeliehood is these bearings/hubs may need to be replaced.. the "walking" across the floor will be accented by the amount of items plus water in the tub. and if the tub is off balance,then this will be more highlighted when also full of water and items... if you feel this is over the top,then try to lighten the load that is in the tub at any given time. this will determine weather the bearing has indeed worn .the lighter the load,the less "walking the machine should do in cycle.. the only time walking would be unchanged is during the spin cycle,when the speed is of a constant one and it will vibrate at the same rate. placing it on a rubber mat is not a solution but just something that will make you hopefully think it is solved
and you may as well just bolt the machine to the floor and hope for the best
