20 Most Recent Kenmore Oasis HE 27082 Top Load Washer Questions & Answers
4answers
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
12/6/2022 11:04:36 PM • Kenmore Oasis HE... • Answered on Dec 06, 2022
48answers
F1 error code on Kenmore Oasis He
After getting the F1 error on my model 110.27086601 and looking at other posts here & elsewhere, I made one call to the "Product Resolution Center" at 800-847-9083 on 4/9/10. They answered quickly, looked up the model & serial number I gave them (begins with CT18) and confirmed that the unit is covered under the "upgrade plan" (as opposed to calling it a recall). They are sending the part directly to me today and they scheduled a Sears tech to come install it in 10 days (or less if the part arrives sooner). The part, shipping and service call are free. The whole call took less than 5 minutes and was no more difficult than ordering a pizza. The agent was polite, professional and a pleasure to deal with.
I'm pleased that 2 years after the warranty expired they are providing this repair free of charge and without any hassle.
To those who have had problems when calling or who will be calling, may I offer this tidbit for dealing with any customer service contact? Be polite and businesslike. The agent on the other end doesn't need to hear about "how disappointed you are, blah, blah" or that you've "been a loyal customer for 84 years" and you've "never had a problem like this" or any other editorial commentary - just be friendly, and say something like " Hi, I have an Oasis washer with the F1 problem and I understand that there's a recall covering this." That's exactly what I said and the agent efficiently handled everything from there.
Remember, the agent gets measured on the number of calls they complete so they just want to take care of you as quickly as possible. Help them by just simply stating the problem and just answering their questions with just the information requested. They are not there to listen to people whine - they've heard everything you have to say a thousand times and they will appreciate your brevity and no nonsense demeanor. Make it easy for them and they'll make it easy for you. Do your venting here if you must.
12/30/2020 2:19:44 AM • Kenmore Oasis HE... • Answered on Dec 30, 2020
27answers
Kenmore Elite Oasis HE top load washing machine F1 code
Ok so you will all love this answer. Not only do I own this set but I also sell them at sears in des moines, ia. Ok so there was a recall on the controll boards it's fine don't be scared all you have to do is call 1800-659-7026 give them your info and model and ser.# they will then send someone out to replace the control board it takes about ten min for all of it and it is all free no matter when you bought it. But in mean time quick fix for all of you is to unplug the washer then hit power then stop over and over tell there is no power left in it then plug it back in and it will work fine for awhile you may have to repeat if it does it again. But after they come out it will work fine. yes this has happened to me it sucks it took two years to find out what was wrong they didn't even tell us I had to ask alot of parts guys and look it all up. So for everyone that this is happening to I'm sorry I just hope this gets out to all of you because I work very hard to know my product and take care of my customers ask any of them and it's not easy working STRAIGHT commission and people don't want to come back for these kind of things. But remember the reason why you came there in the first place we will give you the lowest prices in town and we know what we are talking about, well most do if not they ask me:) so I realy hope this helps someone out there.
9/24/2018 5:33:59 PM • Kenmore Oasis HE... • Answered on Sep 24, 2018
I have a washing machine
check the drain pump,and clean drain hoses.
12/16/2017 6:50:41 AM • Kenmore Oasis HE... • Answered on Dec 16, 2017
2answers
Screen say OL on my Kenmore Catalyst Elite. What does oL mean?
OL error means the Motor Controller has sensed an Overload.The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.If it were a problem with the tub floating up, the unit would spin instead of nutate.Bearing failure in this machine is very common.I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
11/11/2017 3:38:45 PM • Kenmore Oasis HE... • Answered on Nov 11, 2017
Agitator ( nutator) will not function
what is a nutator?i found one time that there's a gear under the agitator that wears and the agitator doesn't move,remove the agitator and you'll see a part with 6 screws in it under that is the part you need to change part W10820039
11/11/2017 3:35:28 PM • Kenmore Oasis HE... • Answered on Nov 11, 2017
My kenmore elite washer gives me a f54 code it wont run thru the cycles in the right order, the basket turns freely and i checked around it and nothing there. had a repair man come out for a service c
if its loud in the spin cycle you have a bad tub bearing and your better off replacing the washer to much to repair
9/30/2017 4:00:16 AM • Kenmore Oasis HE... • Answered on Sep 30, 2017
My kenmore oasis shows the f1 upon starting the ma...
Mine is doing the same exact thing. Just after I press "Start", the F1 starts beeping. Then at 23 minutes into the cycle, it does it again. So frustrating! What is wrong with this machine?
7/31/2017 10:33:18 PM • Kenmore Oasis HE... • Answered on Jul 31, 2017
My Elite Oasis HE washer
call sears 1-800-659-7026 for recall information. Might be the circuit board issue...
7/12/2017 5:11:26 AM • Kenmore Oasis HE... • Answered on Jul 12, 2017
12answers
Washer keeps giving me a "F51" error code? What do I do?
I placed a very detailed post on how to resolve this issue. If you are mechanically and electrically inclined, this will give you pretty much step by step directions. I also analyzed why this is happening. Please disconnect power before any work... There is 120V floating around inside to bite you! Good Luck, GBaxter http://worldofwashers.blogspot.com/2007/06/cabriooasis-f51-error-codes.html
5/2/2017 11:58:18 PM • Kenmore Oasis HE... • Answered on May 02, 2017
2answers
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
5/2/2017 11:44:21 PM • Kenmore Oasis HE... • Answered on May 02, 2017
0answers
2answers
Cycle Signal Won't quit beeping
This is a common problem with the Oasis. The problem is with the interface control board in the console, and/or wiring harness to the board. I have repaired three of these problems in the last 6 months and it was the interface control board each time. The machine will still function normally except for the annoying noise. I don't know of an easy way to defeat the noise functions to the interface control board, or if it should even be attempted. You could cause more harm than good. It can be a bit pricey to replace, and can be tedious to remove. If you wish to attempt to repair, let me know and I can give you some step by step tips on how to remove.
4/1/2016 5:02:41 AM • Kenmore Oasis HE... • Answered on Apr 01, 2016
3answers
My Kenmore Oasis HE is
Sears has a recall for the Kenmore Oasis washer. I have the exact same problem. Call Recall Line @ 1-800-659-7026 with Model number and serial number. The part is a control board that works with the spin cycle.
4/1/2016 4:43:24 AM • Kenmore Oasis HE... • Answered on Apr 01, 2016
Kenmore Oasis HE 27082 Top Load Washer Logo
1,203 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
f1 error code kenmore oasis
  • Washing Machines
