UL is unbalance load. uL is displayed when the machine/motor control detects an
off-balance load, and is steady on while the washer runs a
mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the
load.If the mini-cycle is unsuccessful, uL will flash until the door
lid is opened, allowing the customer to view and
redistribute the load.
Page 57 shows the suspension
rod removal to get the tub out. These rods (4) hold the tub in place. Sorry I do not have an oasis manual but this Bravos manual will give you an Idea. One of those rods could be worn to the point it is throwing the the whole tub off. If a rod is broken then the tub could be pressing against the base and binding the motor, causing that noise. You gonna have to check and see.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
