20 Most Recent Kenmore Elite Oasis 27052 Top Load Washer Questions & Answers
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Kenmore Elite... | Answered on Apr 14, 2018
a repair service for sure .
Kenmore Elite... | Answered on Feb 15, 2018
you NEED to buy real washing soap from a store. I recommend Tide because you may be mixing wrong ingredients or not adding something. If buying new/real soap doesnt work i would go to a sears or email sears at their website and tell them.
Kenmore Elite... | Answered on Feb 03, 2018
Washer Not working at all Symptom Diagnosis Sears PartsDirect The page has tips on what might be the issue. You need the whole part number like 110.27052600 and it could be expensive to repair.
Kenmore Elite... | Answered on Dec 14, 2017
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Kenmore Elite... | Answered on Nov 22, 2017
Probably tub bearings are worn. You can also take Pump off and look to see if any obstructions are there.
Kenmore Elite... | Answered on Nov 12, 2017
I would still replace the suspension rods and bushings. Not much else it could be if machine is level and clothes are distributed evenly. I also have seen the cabinet weld separate at bottom, so be sure cabinet is secure.
Kenmore Elite... | Answered on Nov 04, 2017
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Kenmore Elite... | Answered on Nov 03, 2017
Change belts
Kenmore Elite... | Answered on Oct 28, 2017
Depending on the age of the washer most modern appliances cost more to repair than they are worth.
Your problem sounds like more than a simple filter.
I suggest unplug it, dip the water out of it with a quart cottage cheese cup, then recycle it and purchase a new one.
Kenmore Elite... | Answered on Oct 13, 2017
sounds like a gearbox oil seal,which are not normally replacable tie to replace it
Kenmore Elite... | Answered on Sep 27, 2017
if this is an oasis model. Try pushing other buttons you should get a touch tone (beep) as a good response. if no sound you seem to have a interface problem. not a main ctrl.
Kenmore Elite... | Answered on Sep 19, 2017
Try wd40
Kenmore Elite... | Answered on Aug 13, 2017
The machine may have a defective overload sensor.
Kenmore Elite... | Answered on Jul 22, 2017
Kenmore Elite Oasis 27052 Top Load Washer Logo
1,394 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
Elite Kenmore
  • Elite Kenmore
Most Popular Question
remove lid lock kenmore elite oasis
  • Washing Machines
