Resources for Whirlpool/Craftmaster gas water heater:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.htmlProblem might be diminished air supply or bad venting. Clean the air intake located on bottom of water heater using compressed air or feather duster. Air intake screen is series of openings as wide as razor blade and can easily clog.
Clean the combustion parts and burner. Bleed air/water out of gas line. Check gas pressure.
Check for pilot and venting issues on link above, including tight house, and other gas appliances and vent fans pulling draft down the water heater vent pipe, etc.
Also see service manuals for each type of gas control valve, and replacement steps for each type.
If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
