20 Most Recent LG DLE2514 Electric Dryer Questions & Answers
4answers
Dryer won't turn off.
Is it a mechanical timer you turn (the "clickety-clank"-kind) to set the time? Sounds like something in it has been worn out. Shouldn't be too hart to get a replacement for it,t and you should also probably be able to replace it yourself unless you're very "un-handy", or want to play it safe.
9/19/2022 11:55:39 PM • LG DLE2514... • Answered on Sep 19, 2022
19answers
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
6/12/2022 11:57:17 PM • LG DLE2514... • Answered on Jun 12, 2022
After power on, Filter light flashing with Cotton/towels on and Normal and Delicates light flashing. Reset in diagnostic mode by pushing power and the more time and less time buttons simultaneously.
I just had to say thanku for posting this! This absolutely worked for me on my dryer and I let out a huge sigh of relief. Honestly, probably wouldn't have been able to figure it out on my own! Thanks again!!
7/15/2021 4:34:31 PM • LG DLE2514... • Answered on Jul 15, 2021
My dle2514W LG electric dryer is displaying a CL
My dryer had this same problem. I cleared it by unplugging the dryer from the wall for 20 seconds and then plugging it back in. After this "reset" of the electronics, it has functioned for 2 days without a problem.
4/1/2019 2:56:53 PM • LG DLE2514... • Answered on Apr 01, 2019
LG DLEX2801L Electric Dryer. Won' t stop tumling even when turned off. Only when the door is opened will it stop. The check filter is lit up but I clean it after every use and I have made sure ther
The breaker won't reset? Or the dryer? If it.s the breaker, it is protecting you from a short circuit and a possible electric shock. Are you sure you want to try to fix this without a professional?
2/6/2018 6:27:57 PM • LG DLE2514... • Answered on Feb 06, 2018
I have the LG Tromm DLE2514 electric dryer. It
The cooling light stays on so that is not the issue. Check to make sure you have power in both hot legs of your 220v power outlet.
5/16/2017 3:16:57 AM • LG DLE2514... • Answered on May 16, 2017
Do I locate thermal sensor
3/29/2015 10:01:31 AM • LG DLE2514... • Answered on Mar 29, 2015
Dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
12/15/2014 2:32:26 PM • LG DLE2514... • Answered on Dec 15, 2014
Dryer says check filter and it is clean
Air flow in the duct work is restricted... and the dryer sensor thinks that the filter is clogged.
You will need to take a fluffy cleaning wand and, with the filter removed, try loosening up some of the accumulated line in the duct.
Next, remove the lint pipe from the wall connector and try cleaning it and the pipe for as much distance as you can reach.
Finally, go outside and check the vent. It needs to be clean and clear of obstructions... also, needs to close when the machine is off.
You can do testing on the outside vent with "air dry" setting - hot air is not required... Keep cleaning ductwork until the outside vent passes air freely.
After air flow is restored, the sensor in the "VENT" alarm will act nice.....and stay off
11/6/2014 5:10:34 PM • LG DLE2514... • Answered on Nov 06, 2014
Where is the sensor
If you're talking about the moisture sensor, it's located in the lint filter casing. Remove your lint filter and look inside the casing. About 4 to 6 inches down on the right-hand drum side of the casing and running to the center, you should see two flat metal arcs following the contour of the casing. These metal arcs are the moisture sensors
8/29/2014 1:36:22 AM • LG DLE2514... • Answered on Aug 29, 2014
0answers
Lg dryer wont start lights on on but wont start
Check the thermal fuse, start switch on the control panel and door switch because all three are more likely the cause of the dryer not starting up. The door switch is often the culprit in this type of fault, although a faulty drive motor is not ruled out.
7/5/2014 8:36:40 AM • LG DLE2514... • Answered on Jul 05, 2014
DRYER WANT TURN, MAKE SOUND FOR A MINUTE AND SOUND TURNS OFF.
Check the drum belt.
6/6/2014 12:21:14 PM • LG DLE2514... • Answered on Jun 06, 2014
How to turn off the child lock on a dryer
This information is from the manual: Child Lock can be used to prevent your children from changing options on control panel while the dryer is running. When child lock is enabled, all the buttons will be locked and Child Lock glows. To enable Child Lock, Press and Hold OPTION for 3 seconds, A single beep tone is heard and Child Lock is displayed on the status window. To disable child Lock, press and hold OPTION for 3 seconds again.
5/30/2014 1:03:47 AM • LG DLE2514... • Answered on May 30, 2014
My electric LG dryer has the flow sense and dying and cooling flashing. How to stop it
Do you have a owners manual...?
5/5/2014 10:43:30 PM • LG DLE2514... • Answered on May 05, 2014
LG Sensor Dry DLE2301R power won't stay on unless I hold it down
There is a switch on the motor that could be bad or restricted with excess lint build up.
5/3/2014 7:01:26 PM • LG DLE2514... • Answered on May 03, 2014
328 questions posted
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dryer work check filter light
  • Dryers
