20 Most Recent Whirlpool LGB6300 Gas Dryer Questions & Answers
you need a new igniter. it is a simple fix for a common person that is somewhat handy.
Whirlpool... | Answered on Oct 07, 2016
check the gas supply pressure. if not within required pressure consult the gas company. if there is no problem with gas pressure get to the back of the unit to check the fuse for the gas solenoid valve that controls the flow of the gas. if solenoid valve is faulty, replace it with a good one . . if after installing a new solenoid valve unit still does not kick in , check the igniter . replace with a good one if it is broken , the unit should produce heat now .thanks.
Whirlpool... | Answered on Mar 04, 2016
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Whirlpool... | Answered on Dec 18, 2015
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Whirlpool... | Answered on Apr 15, 2015
If your flame comes on for a few seconds & goes away,replace your solenoids. ($3.00)
If your flame doesn't come on at all, it could be the fuse(unsure of cost) Check the neg/pos lead with an OHM meter(multi meter), to see if there is continuity.
Let us know if this helps!
Whirlpool... | Answered on Jul 30, 2014
Must be something in the blower section. You need to get into the dryer and clean it up. Air restrictions cause overheat condition. When the temp gets so high the limits shut it down. Lots of videos on you tube that show how to get into. You can google gas dryer dan webster or roper dryer no heat dan webster and I have some videos posted how to get into these.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool... | Answered on Jan 15, 2014
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Whirlpool... | Answered on Nov 15, 2013
thats because your not getting gas check solenoids
hydeparkappliancererpair.com
Whirlpool... | Answered on Oct 22, 2013
THis could be caused by a restriction in the blower housing,lint chute ,or exhaust. If you can not hear the fan running the bnlower wheel could have brohen or come off the shaft. You can access this by removing the rear panel and renoving the 4 screws in the lint chute.
Whirlpool... | Answered on Feb 13, 2013
Sounds like a faulty door switch.
Whirlpool... | Answered on Jan 22, 2013
check your sensors, they are in line with the power, basically sensors are switches that are turned on, if something out of the ordinary happens like over heating the sensor like a switch shuts off, it interrupts the power to the energize parts on the dryer and it wont work till the sensor is replaced, sensors have two wires in and out, you should get voltage on each lead to ground with a meter, if not the sensor is broke
Whirlpool... | Answered on Jan 01, 2013
Sounds like the bearing seals may be getting worn. You will need to open the top of the dryer and look for wear marks.
Whirlpool... | Answered on Oct 18, 2012
There are 3 parts that would cause the no heat problem. It is probably just one that is the problem, but the other 2 will soon follow. You will need to replace the "coil kit", the "flame sensor" and the "igniter".
Here is the coil kit.
Here is the flame sensor.
Here is the igniter.
After replacing the 3 parts you will get years of service from your dryer.
Whirlpool... | Answered on Oct 16, 2012
It is the same as an electric model as shown here:
Dryer tune up
Whirlpool... | Answered on Sep 05, 2012
Whirlpool LGB6300 Gas Dryer Logo
211 questions posted
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
gas dryer not dry in timed dry setting
  • Dryers
