20 Most Recent Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Questions & Answers
2answers
Duet dryer wont unlock from the lock mode, even after holding the control lock for 3 seconds
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Whirlpool Duet Dryer
8/28/2021 10:09:41 AM • Whirlpool Duet... • Answered on Aug 28, 2021
Won't heat after gas meter replaced
goto the dryer's manufacturer's site and click on support you should be able to download the owner's manual, the pilot light needs to be relight or the pizeo lighter is not working
1/26/2018 6:41:03 PM • Whirlpool Duet... • Answered on Jan 26, 2018
My whirlpool duet dryer will not allow a normal cycle, it swicthes to delicate or bulky items
The control board is failing... I would use it until it will not dry clothes at all, then get it rebuilt for a fraction of what a new control costs. CoreCentric Solutions Reverse Logistics Core Collection and Recovery... This place rebuilds controls and offers a one year warranty for about 130 bucks
5/26/2016 3:55:05 PM • Whirlpool Duet... • Answered on May 26, 2016
Unplugged duet dryer for two weeks, after plugging back in light in drum comes on but no power to control panel. I have tried resetting and vent is clean, need input, thanks
ELECTRIC Dryer no heat or little heat, or shuts down to fast: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating. The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater. Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity. A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats. Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE 24889723-k4ataymuwmgrdb2rqqdy5pxt-5-0.png 24889723-k4ataymuwmgrdb2rqqdy5pxt-5-2.jpg 24889723-k4ataymuwmgrdb2rqqdy5pxt-5-5.jpg
5/7/2015 9:55:22 PM • Whirlpool Duet... • Answered on May 07, 2015
Our electronic control panel won't work.
Duet dryer service manual
This video shows how to replace a thermister. OK right next to the thermister is the thermal fuse3cd2684.jpgUnplug the dryer before attempting any repairs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3/29/2015 10:45:15 PM • Whirlpool Duet... • Answered on Mar 29, 2015
Whirlpool duet dryer
usually a broken belt or has come off pulley
9/1/2014 1:19:12 AM • Whirlpool Duet... • Answered on Sep 01, 2014
What does error E 1 indicate on dryer??? Stops running after 5-6 minutes flashes this error
Whirlpool Dryer Fault Codes This should help with any error codes you may receive.
8/1/2014 1:40:03 AM • Whirlpool Duet... • Answered on Aug 01, 2014
What is wrong with a whirlpool 4 cycles 3 temperature dryer that will not get hot?
First clean the vents inside the dryer and to the outside be sure and clean around the blower wheel. Check the thermal fuse, the cutout fuse & all the thermostats. Check the heating element also check that it is not grounded to the heater box. Last check the centrifical switch on the motor as the heater runs through it. Hope this will help you
6/2/2014 4:33:43 AM • Whirlpool Duet... • Answered on Jun 02, 2014
How to know if motor is bad
I am a WP tech need exact model number dont change many motors does the unit power up and when you push start do you hear a click if so probably an open fuse again model # will show you how to place in diagnostic
3/23/2014 3:33:30 PM • Whirlpool Duet... • Answered on Mar 23, 2014
One of the plugs going to the main circuit board
A couple things you could checkLook at the original main circuit board and see if there are any brown spots on there, that would be a indicator of it overheating, look on the opposite side of the plug socket. I am not too familiar with the dryer style, but if the main circuit board is down by the burner area or by the exhaust do a visual inspection and look to see if there is any obstructions or holes. I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
8/24/2013 5:36:08 AM • Whirlpool Duet... • Answered on Aug 24, 2013
Whirlpool frontload dryer trips circuit when
The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker. If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
8/3/2013 5:40:43 PM • Whirlpool Duet... • Answered on Aug 03, 2013
Tick noise gas line from gas dryer up to kitchen stove
sounds as if you igniter is trying to continually lite not sure about how flame senser works on that model but normaly senser is right next to flame may have been bent away from flame I am use to older models
2/14/2013 3:09:17 PM • Whirlpool Duet... • Answered on Feb 14, 2013
Runs but no heat
What is the model number of the unit?
11/30/2012 10:34:50 AM • Whirlpool Duet... • Answered on Nov 30, 2012
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
10/20/2012 10:40:16 AM • Whirlpool Duet... • Answered on Oct 20, 2012
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
107 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
whirlpool gas dryer runs
  • Dryers
