20 Most Recent Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Questions & Answers
Hi
Press and Hold the End of Cycle Signal Button for 15 seconds, this will unlock the control lock of your Whirlpool Duet. Hope this helps...please post back for further assistance.
Daniel
Whirlpool Duet... | Answered on Dec 01, 2018
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Whirlpool Duet... | Answered on Feb 02, 2018
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Whirlpool Duet... | Answered on May 04, 2017
press the "lock" button for like 5 full seconds and see if goes out
Whirlpool Duet... | Answered on Dec 01, 2016
Suggest the following.
  • Check drum light. No light defective door switch. Light yes one leg of 220 circuit OK.
  • Be very sure motor doesn't start when you set to run. Belt may be off the motor and motor is very quite. Fix belt. Motor may be stuck or failed listen to hear if it is buzzing
  • When pressing start button listen for distinctive run relay activation. If when the start button is depressed I would expect to here the relay.
  • Motor run circuit relatively simple. The drum motor and blower are one assembly.
Whirlpool Duet... | Answered on Nov 30, 2015
Check the door interlock switch. You should be able to hear it click as you open and close the door. It is easy for it to snap out of place on some models. You can operate it by hand to check the action.
Hope this will help
Whirlpool Duet... | Answered on Nov 28, 2015
no, but there is a thermal fuse, normally located on the blower duct, near the blower wheel. More than likely, that's the issue if it doesn't start.
Whirlpool duet sport F21 error code fix - YouTube
? 4:39
https://www.youtube.com/watch?v=qQTvBSnEWsI
Feb 22, 2010 - Uploaded by heli400
Also note TROUBLE SHOOTING MANUAL IS TAPED TO THE ...I have replace 6 detergent ben hose 1 motor the membrane on thebuttons .... I've owned the washer for 6 years and I never knewthere was a filter underneath!
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
I have a Whirlpool Duet MOD GEW9250PWI It's not making any noise, ... only" I've unplugged it and plugged it back hoping it would reset it. ... The service man I use stated it was the motorgoing bad, the smell of ... i checked the door switch, it was fine too i believe. so thermal fuse ... There still is not start up.
If you have a similar conectio as mine, you can't
Whirlpool Duet... | Answered on Nov 06, 2015
Hello. First, turn the power off to the dryer or remove the power cord from the AC outlet. Next, locate the 2 screws in-between the upper and lower front panels and at the bottom front of the dryer--there will be 2-3 screws, usually 1/4 inch hex head, and remove them--use a magnetic nut driver, it makes it a whole lot easier! (note:sometimes, to replace the panel, you have to push up on the bottom of the panel hard to get the screw holes to line up again.) Set the panel aside. Open the dryer door and remove the lint screen from the holder. Close the door. Next, notice the blower housing cover, pic 3, #45, lower left corner. There should be 3-4 screws holding the cover to the blower housing. Remove the screws and cover--use caution--most metal edges inside a dryer are unfinished and razor sharp--akin to putting your hand inside a box of razor blades(ask me how I know this, lol). Remove any lint build-up inside the cover with a vacuum. Again, using a vacuum, suck out any lint from inside the blower housing and fan as best you can. Take care to not damage the fan blades! Now, try to remove as much lint build-up as you can with the vacuum. Be especially careful when vacuuming around the mouth of the heater element. Do the best you can. At this point, re-assemble the dryer using the reverse of assembly. If there is still a lot of lint inside the cabinet and you can't reach it--STOP! In order to remove the remaining lint requires removal of the front bulkhead(large metal plate that supports the front of the drum), drum belt, and drum from the cabinet. This is INVOLVED and can be very difficult to re-assemble if you have never done it before. Call for service. I hope I helped you!
Whirlpool Duet... | Answered on Oct 03, 2015
Bottom panel. But you shouldn't be able to put harness connector in the wrong terminal. The normally all have their own special cut in the board or they will be color coded.
Whirlpool Duet... | Answered on Aug 01, 2015
Sounds like a main control issue. I would call a service technician for further investigation. Try shutting the breaker off for 10 minutes or so and see if this corrects the issue.
SORRY TO SAY IT BUT SOUNDS LIKE BAD MOTOR WINDINGS HERES HOW TO TEST THEM
Whirlpool Duet... | Answered on May 07, 2015
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
414 questions posted
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
changed drum support rollers put back
  • Dryers
