20 Most Recent Lakewood HV 18-c Floor / Box Fan Questions & Answers
We do not sell anything here, you are on the wrong website.
Lakewood HV 18-c... | Answered on Sep 06, 2017
Fan remote stopped working. New battery installed.
Lakewood HV 18-c... | Answered on Apr 17, 2016
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
Lakewood HV 18-c... | Answered on Jul 16, 2015
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
White is the common or neutral...
Black is the high speed...
blue is medium...
red is low speed...
hook them up right in that order....
heatman101
Lakewood HV 18-c... | Answered on Jun 21, 2015
You need to clean it and oil the bushings. When this doesn't solve the problem, change the start capacitor. If it continues to hum or make noise, replace the bushings. A repair technician may be helpful.
Lakewood HV 18-c... | Answered on Jul 14, 2014
If you remove the cover screen and take compressed air or just a brush to clean out all dust and dirt from the motor the fan may run again
Dust is a standard contributor of these fans to quick turning
Lakewood HV 18-c... | Answered on Jun 16, 2014
Lakewood HV 18-c Floor / Box Fan Logo
73 questions posted
Top Lakewood Dryers Experts
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
View Most Popular
Lakewood Dryers
  • Lakewood Dryers
Most Popular Question
lakewood fan fuse
  • Dryers
