Maytag Neptune FAV6800AW Top Load Washer Logo
Posted on Jul 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer will not spin. Does fill and agitate.
Washer will not spin on any part of any cycle setting where it is supposed to spin and drain. Does agitate though.
Anonymous
Level 3:
  • Master 526 Answers
  • Posted on Jul 19, 2010
Anonymous
Master
Level 3:
Answers
526
Questions
0
Helped
143125
Points
1214
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 96 Answers
  • Posted on Jun 13, 2013
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
96
Questions
0
Helped
14327
Points
190
It may be a problem with the pressure switch,,,or clutch if it has a clutch driven motor
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
734
Points
Wsaher will not spin on any cycle. I have the Maytag Neptune 6800AW model
1helpful
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
You start the washer and the water will fill up to where it is suppose to but will not start to aggitate.The water will drain but the drum won't spin,than it will fill up again and it won't agitate...
Your drain hose is maybe too low and therefore gravity is draining out the washer OR the drain hose is too tight in the drain and a siphoning effect is happening.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
8helpful
2answers
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
