20 Most Recent GE Profile WPRE6100G Top Load Washer Questions & Answers
do you need just the hub or do you also need the basket...I can sell you a hub.. let me know
GE Profile... | Answered on Mar 19, 2019
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
GE Profile... | Answered on Dec 30, 2018
The cycle timer is "hanging".
GE Profile... | Answered on Jan 27, 2018
Would check belt for tightness and it is also possible you have a dry bearing in pulley, motor etc.
GE Profile... | Answered on Jan 16, 2018
check water solenoid or leakage from hoses or water level swith
GE Profile... | Answered on Dec 18, 2017
FIXYA has no way of knowing what they are or where they come from .we have no field techs . suggest you call a repair service
GE Profile... | Answered on Nov 05, 2017
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
GE Profile... | Answered on May 19, 2017
lucky that the machine is plastic or you would be getting a shock
red wire is active , black wire is neutral and the green with yellow is ground
all of the wires have a color code for a purpose and must all be connected correctly
connect the pump correctly and the fault will dissapear
GE Profile... | Answered on May 12, 2017
Most likely the knob is defective, order a new one.
GE Profile... | Answered on Apr 25, 2017
I suspect the main bearing.
GE Profile... | Answered on Mar 01, 2017
GE Profile WPRE6100G Top Load Washer Logo
579 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
machine works but will not light up
  • Washing Machines
