NorStar CallPilot 100 Logo
Posted on Jul 01, 2010
Invalid feature and 2 lights lit
Plugged the unit into the system, all lights worked properly, waited a half hour to program the voicemail boxes, all lights were off. restarted the unit and now it only has 2 lights lite with invalid feature showing.
Anonymous
Level 1:
New Friend:
  • Contributor 105 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
105
Questions
0
Helped
41531
Points
Two lights lit is the normal situation - it means that the two voicemail ports are connected to the Norstar System and active. Press "Feature 9 (star) 1" to view the CallPilot Feature Codes. Then enter System Administration feature code to begin programming the system.
Good Luck!
I have a panasonic home phone want to remove the voice mail sign and light flashing
To remove the voicemail indicator and stop the flashing light on your Panasonic home phone, you can try the following steps:
1. Access the voicemail system: Dial your home phone number from your Panasonic phone or another phone and let it ring until it goes to voicemail. Enter your voicemail password or follow the prompts to access your voicemail messages.
2. Listen to and delete all voicemail messages: Check your voicemail inbox for any new or saved messages. Listen to each message and follow the instructions to delete them. Ensure that your voicemail box is empty.
3. Exit the voicemail system: Once you have listened to and deleted all voicemail messages, exit the voicemail system by following the prompts or hanging up the call.
4. Reset the phone: Disconnect the power adapter from the back of your Panasonic phone base unit. Wait for about 30 seconds and then plug the power adapter back in. This will perform a reset on the phone and clear any residual indicators.
5. Check the voicemail indicator: After the phone has rebooted, check if the voicemail indicator is still active or if the light is still flashing. If the issue persists, proceed to the next step.
6. Disable visual voicemail feature (if applicable): Some Panasonic home phones offer a visual voicemail feature that may trigger the voicemail indicator and flashing light. To disable this feature, consult the user manual for your specific model and follow the instructions to turn off the visual voicemail function.
7. Contact Panasonic support: If you have followed the above steps and are still unable to remove the voicemail indicator or stop the flashing light, it's recommended to contact Panasonic customer support for further assistance. They can provide specific guidance based on your phone model and help troubleshoot the issue.
Remember to consult the user manual for your Panasonic home phone model as the steps and features may vary slightly.
this video might help
3answers
Norstar M7310 all features inactive
I have been asked to advise, but sadly I am totally ignorant of the product,or its likely method of operation.
I wish you well, and I'm sorry that I cannot help or assist.
robert
I have a M7310 Norstar and at this time all features are invalid. What can be done to fix this problem? Cannot access voice mail, cannot transfer calls to a voice mail, etc.
If none of your voicemail features are working(F980- F989) then somethings wrong with the voicemail itsself. Check to see if the power light is on inside the voicemail cabinet. If its lit, then try cycling the power on and off and wait abot 10 minutes to see if the voicemail comes back online.
2answers
Norstar system won't recognize any features We had a power outage and now our phone system will not recongnize the voicemail or mailbox features. Is there any way to fix this? Thanks
Depending on the type of voicemail it can take up to 10 min, to fully come up. Is the power light lit in the voicemail cabinet? Also what kind of voicemail is it?
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
1helpful
2answers
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
2helpful
Norstar: Inactive Feature (981)
This generally happens from one of two things. Your voice mail system is connected to your phone system through a station port. If it loses connection it will not communicate with the phone system. Loose wire or connection can cause this. or it has just crashed and will need repair or replacement.
First thing you want to do is unplug the unit wait 15 minutes and plug it back in. wait 10 minutes Try feature 981 from a set that has voicemail. if nothing. hit feature 985 from a m7310 set or a m7324 set not a m7208. If it comes back with inactive fearture now your connection between the units is bad or the unit itself is bad. If it comes back with the voicemail intercom # and you cant get into any mailboxes it has lost all programming.Try this first.
2answers
Inactive Feature
The system lost programming. Call a vendor in...
2answers
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Top NorStar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
