20 Most Recent
NorStar BayStack 425-24T (AL2012E41) 24x10/100 Mbps and 2x1000 Mbps Networking Switch Questions & Answers
Baystack 425-24T Port 26 disabled
I did what you sugget. Went to CLI and did :
conf t
stacking-mode disable
boot
After the reboot, port 26 is enabled and working. Thanks
Baystack 425 flashing amber on all ports
Make sure you're using the correct console cable...if it's not wired correctly, hyperterminal will continue to give you a blank stare no matter what you do. A great way to verify your cable is to try it on another switch that's working ok. Your hyperterminal comm settings should be 9600 baud, 8 data bits, one stop bit, no parity, and flow control disabled...assuming no one changed the default console settings on the switches.
If you are still having trouble getting a prompt from the console, you can try the following procedure, although this is only known to work on earlier versions of the Baystack switches...
Shut down the power and wait for about a minute. With hyperterminal connected...turn on the power and type "NetICs" (don't include the quotes) within 15 seconds of turning on the power. This should place you in a privileged mode and allow you to use the menu to reset the switches to factory defaults. Good luck!
Gbic
Hi from the command line interface you will need to login and then type enable (enter) configure (enter), interface fast ethernet all (enter), no shutdown port (port #).
Here is a link to the CLI manual if you need more help:
http://www116.nortel.com/docs/bvdoc/baystack/doc_pdf/217152-A_CLI_Guide_for_Ethernet_Switch_325-425_Release_3.5.pdf
Let me know how it goes or if you need more help.
Regards
How can i test the battaries in the ups battary
Hi Yazan,You need a battery tester in order to test the amps that a battery would output. From your description, they are at their end of life and you will need new buy new ones.Reply or call if you need more help with this -- 800.260.2259
11/1/2013 8:44:12 PM •
NorStar...
Answered
on Nov 01, 2013
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
