20 Most Recent Nortel T7316E 2-Line Corded Phone Questions & Answers
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Nortel T7316E... | Answered on Oct 12, 2017
To establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press feature button then 3.
5. Press the line or intercom button of the first held call (not required on the
T7100/M7100 telephone).
6. Press Release to end the conference call.
To remove yourself from a conference permanently
(unsupervised conference):
Press feature buton then 70. The other two callers remain connected. (Some
external lines may not support this feature. See your system
administrator.)
To put a conference on hold:
Press hold. The other two callers can still talk to each other.
To split a conference:
Press the line or intercom button of one caller to consult privately while
the other caller is on hold. To re-establish the conference, press
To disconnect one party:
Press the line or intercom button of the caller you want to disconnect,
then press Release button. Press the line or intercom button of the remaining
caller to resume your conversation.
Nortel T7316E... | Answered on Dec 08, 2016
email me and i will solve your bcm50 problem with forwarding phone info at businessphonecanada dot com
Nortel T7316E... | Answered on Feb 04, 2016
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Nortel T7316E... | Answered on Nov 10, 2015
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Nortel T7316E... | Answered on Aug 20, 2015
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Nortel T7316E... | Answered on Jun 28, 2015
You don't. Only the administrator who set that restriction can undo it.
Nortel T7316E... | Answered on Apr 29, 2015
Go into the programming mode and scroll down to Time and date. You can change it at that point .
Nortel T7316E... | Answered on Mar 24, 2015
Call Log is a feature which has to be enabled for that station at the central switch. See you administrator,
Nortel T7316E... | Answered on Feb 02, 2015
Feature # 85
F85 turns it on
F#85 turns it off
Nortel T7316E 2-Line Corded Phone Logo
354 questions posted
Top Nortel Lands Phones Experts
Sanjaya Sahu
Sanjaya Sahu
deton8 von Splosion
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Nortel Lands Phones
  • Nortel Lands Phones
Most Popular Question
trying disable paging t7316e phone
  • Lands Phones
