20 Most Recent NorStar Meridian M7310 Phone Questions & Answers
I guess you want a page key programmed on your set. press feature *3, press a memory key, press feature 610. This key pages all sets when pressed.
NorStar Meridian... | Answered on Sep 26, 2017
Just think about it, why would you want to auto dial yourself? You don't need an autodial key for yourself so the system don't allow you to program it.
NorStar Meridian... | Answered on Sep 25, 2017
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
NorStar Meridian... | Answered on Jun 21, 2017
If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
NorStar Meridian... | Answered on Feb 24, 2017
There is a triangular button on the phone, there might be a light on it. That is the "shift" button for the "Speed dial buttons". They have 2 "positions on each, normal and "Shifted"
NorStar Meridian... | Answered on Oct 11, 2016
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
NorStar Meridian... | Answered on Mar 24, 2016
what a load of you know what.
contact your service provider, it more than likely has something to do with the type of plan you are on!
NorStar Meridian... | Answered on Aug 30, 2015
Press handsfree/mute key.
NorStar Meridian... | Answered on Jul 22, 2015
You have what they call a caller id trunk card in your system this could have failed you could try powering down the system to see if that dosen't help wait 2 or 3 min. the power it up.
NorStar Meridian... | Answered on May 01, 2015
Check your button programming using Feature *0 to see if the lines are programmed to your phone.
NorStar Meridian... | Answered on Apr 21, 2015
push feature key then star zero don't lift handset this is called botton enquiry. this allows u to push any key and the systyem will identify whats on that key and not disrupt phones.
NorStar Meridian... | Answered on Mar 14, 2015
unplugging should work for that
NorStar Meridian... | Answered on Mar 12, 2015
NorStar Meridian M7310 Phone Logo
491 questions posted
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • NorStar Lands Phones
Most Popular Question
message displayed but no messages in
  • Lands Phones
