Frigidaire FRS26R4A Side by Side Refrigerator Logo
Posted on Jun 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frig not cooling at all
Frig side not cooling freezer side just fine have checked control settings etc 10 yr old side by side
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Jun 12, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10845639
Points
101584
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorfrig not cooling at all - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
1helpful
8 yr old maytag msd2758drw side by side isn't freezing
If the clicking noise is comming from the rear of the frig it could be your compressor trying to start. The motor would be the fan in the freezer running. That part would be normal.
If it is the compressor it could be replaced but if it were me I would buy a new frig.
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
1helpful
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Whirlpool side by side refrigerator not cooling
yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
1helpful
Jenn-Aire JCD2389GES Side by Side: Frig not cooling fully - freezer fine
i'm thinking that maybe an air duct is either blocked or the damper isnt opening. In the freezer compartment at the top right side there is a cover that is held in place by 1 screw. (look at item number 35 here). remove this cover and make sure ice is not blocking it up. if that is ok, then check the damper control to be sure it is opening and closing properly. The damper is located on the refrig side in the control cover (look at item# 8 here).
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
