Hi there brad
power led just turns on and after a while, flashes...no picture comes out and no sound as well?
please check if there is blown fuse in the curcuit board. please check also the STK's 392-010 because this is a rear projection tv right. be sure to check also the resistors that are mounted under the heatsinks of the STKs, they may be changed in value and might have opened.
it is also ok to the the vert ic and its protector to check if this has gone bad. usual symptom when the vert ic goes bad is the timer power light goes off and flickers .
posat back for any results.
please also check ginkos post, its a sony.
here are the numbers to ring a sony service place...
Sony Business Solutions & Systems Parts Support
Parts orders, exchanges, parts lookup and status
Hours of Operation: Monday - Friday 9:00am - 7:00pm Central Standard Time
Phone: (800) 538-7550
Fax: (816) 880-6854
Operations and Technical Support
SONY ELECTRONICS INC.
ATTN: CUSTOMER SERVICE
2520 Zanker Road Mail Stop ZNK5
San Jose, Califiornia 95131
FAX: (408) 352-8283
Sony Business Solutions & Systems Technical Assistance Network (TAN)
Telephone support for technical / repair of Sony Business Solutions & Systems Products.
Hours of Operation: 8:30am - 8:00pm Eastern Standard Time
Phone: NEW TOLL FREE NUMBER (866) 766-9272
Note: When contacting your local service center select "service" at the auto-attendant prompt.
Then select option " 1" for TAN.
Listen for the Product category descriptions then make the appropriate selection relative to the product being serviced.
Your call will be routed to the next available Service Engineer specifically trained for that Mode
hope this helps you in many ways possible.
thanks for using fixya.
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis
function. If the timer/standby indicator is blinking, this could be an
indication of the problem with the unit. The diagnostic blinking will
occur automatically with no action required by you to engage it.The
timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses
for 3 seconds, then the two to eight blinks about a third of a second
apart again. Here is a list of the problems that might have occurred
indicated by the number of blinks. The words in parentheses are those
which you will see for
each of these faults on a diagnosis screen described later in this
article. Unit is dead and there are no blinks---Problem in the standby
power section. Might check fuse, R607, Q601, IC601, R612 and VDR601
(should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the
standby mode then displays the 2 blink fault. Could be a short in the
power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the
standby mode then displays the 3 blink fault. This is also a problem in
the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for
about 30 seconds then goes to the self-diagnosis function. Something is
wrong with the video. Check video out, Q705, 732, 761 and other
components on the C board, also check Q218, 219, 220 on the A board.
Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking
selfdiagnosis function immediately. Check C515 & 516 and the jungle
IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and
402.Intermittent problems ? This is a great feature. You can also bring
up these fault codes ON-SCREEN to see a list of the problem numbers
with the abbreviation of the problem and the number of times this
problem has occurred. This is slightly different than entering the
service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have
occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks"
described above so you can correlate between the diagnostic screen and
the blink codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is
blinking 4 times....This would tell you that you have no vertical and
that is why the video is muted. If it was blinking 6 times, you would
know that you have a horizontal fault.It's not a sure cure, but it's a
little better than a poke in the eye with a sharp stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault
is corrected, so if you don't clear them, you'll be seeing "old" fault
codes the next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course
returns everything to the factory preset condition.
Follows:
Ten blinks -Nine blinks - Replace D 6116 and D 6301
on the "G" board, do not resolder as this will fix the problem
temporary. Or Panel Module Error or Thermal Error. If it is
intermittent 9 blinks, meaning sometimes the TV comes on and other
times you get flashing, then change the switching regulator on the "G"
board or check connections. Make sure the regulator is -12 or -13
(negitive).
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on
the " D" board. If the transistors are bad, check R8051 and IC8005,
also on the "D" board.
You need to check or have checked and eventually replaced : Q8014 and Q8013 for shorts, leakage, or bad solder connections on
Contact a service in your area and tell them it is blinking red ten times, so that they will know that the problem is HV Protection fault, and they can give you a quotation for the repair.
Regards
It flashes green, and actual stays on for about 10 seconds or so then automatically turns off and flashes red ten times. Dont know much about tv's so might just ring a sony service place.
