Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
Posted on Apr 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire Gallery gas range, oven door will not remain open. When the oven door has been opened, it will not stay open, goes up immediately. Very dangerous, can spill and burn person using the oven. Appreciate any and all suggestions. Thank you.
Hjalmer Lamminen
Level 3:
  • Master 552 Answers
  • Posted on Apr 02, 2008
Hjalmer Lamminen
Master
Level 3:
Answers
552
Questions
Helped
236687
Points
1540
There may be a broken spring that helps the door stay open.
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
How do i fix the light socket to my Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
Oven door won't open after self-cleaning. Open it
Unplug the range.
Remove the back panel.
Look for the long rod going from the back to the front of the oven.
Manually push on this rod to unlock the door.
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
1helpful
Frigidair Electric stove (MN) CFEF358EC
F90-Maximum oven door unlock time exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch. 2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary. 3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam. 4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, repl;ace Lock Motor Assembly. 5. (F90, 91, 92, 93 & 94) Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly. 6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch. 7. If all situations above do not solve probem, replace EOC.
Locked oven door
Try unplugging the oven for about 30-45 minutes. Plug it back in and see if the door will open. If not, you have a bad latch, interlock microswitch or control board.
Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Gas range
I have a frigeidaire classic gas range 12 years old worked fine until a pot of water leaked over the stove top burners. now the door locked lite is on and the door lock is activated , the oven door is open and won't close. The oven also does not work now, although the stove top burners work fine.
Can you help ? Thanks, Tom
Troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
