20 Most Recent
Hotpoint RGB745 Gas Kitchen Range Questions & Answers
My Hotpoint WMF740 washing machine is displaying
it very well is the door switch might be stuck. The way to unstick it is to slam the door. Very often it'll jar the switch loose if that doesn't work you'll need to order one. Easy to install there are youtube videos on it. If you need the part...try here...repairclinic.com or appliancepartspro.com.
Hope this info helps a little.
Oven clock replacement
If you are sure you have the correct clock for your model have followed instructions completely, tape up loose wire ends individually and give it a try.
How to fix igniter for top burners
Hello. The range you have has a spark ignitor module inside the top, beneath the cooktop. Also, there is a spark ignition harness that has the four switches(snapped onto each of the burner valves at the control panel) connected together(daisy chained) that goes to the module and the incoming 120v supply. HOWEVER, the bigger issue here is getting to the module, harness, and other parts beneath the cooktop. Gas ranges are notorious for having the mount screws seize in the burners. When removing them is attempted, the heads usually snap off causing burner replacement to be necessary(which is why I listed the part numbers for the burners and screws). The cost of this can be high. I suggest calling for service if you are at all hesitant about working on the range.
BURNER SCREWS(8) WB1K84
BURNER HEAD RR WB16K12
BURNER HEAD LF WB16K11
BURNER HEAD RF WB16K10012
SPARK MODULE WB13K25
HIGH VOLTAGE HARNESS WB18K06
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Can't seem to access Hotpoint Stove Pilot Light?
Your range uses electronic ignition, not pilot lights. For surface burners the igniter sparks when the gas valve is turned to the "light" position. All burners should spark when any gas valve is in the light position. For the oven the ignitor is also electric but does not spark but rather heats up or glows. What is the problem with your range?
How to clean an oil spill
All of you are MORONS. the guy is asking "quite clearly", how to remove the bottom pan so he can clean under it. It's quite obviouse he understands how to clean the the main part of the oven. He just want to know HOW TO REMOVE THE BOTTOM PAN.......
