20 Most Recent Frigidaire Gallery GLEFM397DS Electric Kitchen Range Questions & Answers
Sylvain, Probably a burner coil or connector is probably faulty. Have checked and replaced.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Frigidaire... | Answered on Feb 28, 2016
This is a inner/outer burner type assembly? Sounds like a glass top.
Either way, your switch for that burner or the burner needs to be replaced.
If you are able and it is possible, inter change switches to see if it makes a difference. Interchange Large with large, small with small.
If yous switches are connected as one unit, you will not be able to do this. Sorry, I have not looked up your wiring diagram.
Frigidaire... | Answered on Mar 22, 2015
I appreciate your inquiry, friend!
I see that you are having an issue with your digital clock shutting off on your Frigidaire range. This could be a potential short within you wiring harness or control panel. I would recommend performing a reset on your range and you can do that by disconnecting power from your range for roughly ten minutes. If that does not correct your issue you may need to have an electrical component replaced and that is not a simple DIY job. I would suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Frigidaire... | Answered on Mar 12, 2015
Unscrew all parts and lay them out on the garage floor. Scatter them and mix em up good. When done, try and figure out what goes to what. If you have parts left over when done reassembling; just toss them out.
Frigidaire... | Answered on Dec 10, 2014
Good Afternoon Friend, this is Z. I am happy to assist you!
I understand the burners on your Frigidaire range are working, however you are having trouble with your oven. Do you have an electric or gas range? Can you elaborate prior to your problems any other symptoms or specific error codes before having this issue? Also, may I have your model number please? The serial tag, which lists your model number, is typically located in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem. Thank you!
Frigidaire... | Answered on Jul 18, 2014
Good Morning Mike, I am happy to assist you!
I understand the oven lockout feature is activated on your range. Try pressing and holding the LOCK symbol for approximately five seconds. A beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Your range should resume normal operations. I ask that you please follow up with a comment on the post, at your convenience to advise if further troubleshooting is needed or if your range status has changed successfully. Thank you!
Frigidaire... | Answered on Nov 08, 2013
Good Afternoon Donna, thank you for your post!
Let's try resetting your range by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Is the unit still advising that the door is locked? An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the EOC (Electronic Oven Control) and door latch assembly, or a potential wiring failure.
Frigidaire... | Answered on Sep 30, 2013
Good Morning Sandy, thank you for allowing me to assist you!
I understand you are seeking information regarding the self-clean feature for your above-listed range model number, GLEFM397DS. I have located the Owner's Guide on the manufacturer website and you will find step by step instructions on how to do so from pages 32 through 34. Hope this proves helpful! If you have further questions, please do not hesitate to reconnect.
Frigidaire... | Answered on Sep 26, 2013
Good Afternoon John, I am happy to assist you!
I understand you are seeking a manual and I'm assuming your model number is GLEFM397DS, posted above. If so, I have located the Owner's Guide on the manufacturer website. Here you will be able to access step by step instructions on how to operate the oven. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Frigidaire... | Answered on Sep 16, 2013
Hi Jeff - Thank you for your question and I understand that you are seeking information on how to adjust the oven door. However, more than likely the hinges would either need to be loosen/tighten or replace depending if they are too damaged. The weight of some range doors and how they are closed can wear over time. Personally, I would recommend contacting the manufacturer to see if they have any updated or alternate door hinges that you can install yourself since this can be a complicate job.
Frigidaire... | Answered on Jun 07, 2013
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
137 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
frigidaire gallery glass stove top
  • Kitchen Ranges
