20 Most Recent Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Questions & Answers
Well if that is really happening you would need to make sure that the temperature gauge is working properly
Frigidaire... | Answered on Aug 02, 2016
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Frigidaire... | Answered on Apr 04, 2016
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Frigidaire... | Answered on Apr 02, 2015
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Frigidaire... | Answered on Jan 02, 2015
My guess is it's in the oven box towards the top. looks like an ice pick and screws to the oven wall. Find where the wire feeds through the wall and remove the access cover behind it. It can be disconnected and checked for ohms. No model number, so replacement parts are easy to look up by model number. 25315439-zejmo41uy3tce5x43qikgza0-5-0.jpg
Frigidaire... | Answered on Dec 10, 2014
Thank you for your post, friend!
I would suggest either your switch or element could be causing the problem within your burners. I would perform a reset on your appliance which you can do by unplugging your power cord or flipping the household circuit breaker for ten minutes.
If that does not help correct the issue I would recommend reaching out to a professional for proper diagnosis and repair of your range. I hope this is helpful. -Matt
Frigidaire... | Answered on Oct 07, 2014
Yes, it should.
Frigidaire... | Answered on Aug 22, 2014
Hello friend, thank you for your post!
I understand that you need to fix a sprung oven door on your Frigidaire range. If you need to replace the hinges or door we recommend seeking assistance from a professional. Some of these intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Frigidaire... | Answered on Aug 20, 2014
Good Afternoon Friend,
I understand that your Frigidaire range overheated, so you unplugged it and plugged it in the next morning. I also see that when you plugged it back in there was a "PF" code displayed as well as some melted plastic. The "PF" code means that there was a power failure. You can clear that by pressing any button. As far as your appliance overheating and melting plastic, I suggest contacting the manufacturer directly for further assistance. They might be able to point you in the right direction to have it repaired. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 08, 2014
Hello Friend, this is Z. I am happy to assist you! I understand you have a Frigidaire electric range, FES388; however what exactly is your concern? Are you seeking an Owner's Guide or are is your range experiencing an issue? With this information I can better address the issue at hand. Thank you!
Frigidaire... | Answered on May 25, 2014
Those units will not unlock until the interior temperature goes down to a safe level. Self cleaning cycles approach 900 degree F and reduce anything inside to ash. Wait a few hours for oven to cool down and ........
Frigidaire... | Answered on Mar 17, 2014
Check your oven sensor is what I would do. See if it reads 1100 ohms at room temp. If it is open or shorted it is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Frigidaire... | Answered on Dec 26, 2013
What is the model number of your unit?
Frigidaire... | Answered on Oct 20, 2013
Hello Karen, thank you for your post!
Since you just received your unit recently, let's try resetting the range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the range on. If resetting the power does not correct the issue, your appliance could possibly have a faulty burner or a potential wiring failure to the burner. At this point, I would highly recommend contacting or visiting the manufacturer website to find a service provide near you and to verify warranty information. If there is anything else that I can help you with, please feel free to reconnect!
Best of luck!
Frigidaire... | Answered on Sep 30, 2013
Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
Popular Tags
194 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
frigidaire gas range 3 5 burners not
  • Kitchen Ranges
