20 Most Recent GE Profile Spectra JGBP90 Gas Kitchen Range Questions & Answers
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
GE Profile... | Answered on Dec 22, 2018
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
GE Profile... | Answered on Jul 26, 2018
1. Do both coils get red hot? Try with bake @ 400F, then with broil to be sure. I recently had a bad lower bake coil, but the oven got hot slowly since the broil top coil comes on periodically to even up the heat in the oven. Replacing the lower coil was easy, about a 15-min job, but I had to pre-tap the screw holes on the coil terminals since my oven had extremely short wires.
2. If the coils are ok, the problem may be with the thermocouple or control board.
GE Profile... | Answered on Dec 26, 2017
call a certified repair service . your gas valve has failed . DIY is not suggested on gas appliances due to safety reasons
GE Profile... | Answered on Sep 15, 2017
If you cannot get to clean it fully then open your windows, place a fan in the doorway to encourage the smoke to leave the house and put it on a cleaning cycle.
Use aluminium foil to line the base of the oven rack. That will stop this from happening again when your containers are overfilled.
GE Profile... | Answered on Jul 23, 2017
1,583 questions posted
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
ge xl44 gas oven
  • Kitchen Ranges
