20 Most Recent Frigidaire FGF378AC Gas Kitchen Range Questions & Answers
Shut oven off & call the gas company. This is nothing to mess with. Seriously.
Frigidaire... | Answered on Nov 15, 2017
Plastic explosives, anyone?!
Anyway can the electronics on that puppy can be reset? If not successful either check with mfg or google it. Good luck!
Frigidaire... | Answered on Sep 21, 2017
local contractor came back. Said 6 other people have reported the problem according to Frigidaire.  Wasn't home so I don't know exactly what they did but they claimed to have moved some wires around.  So far no problems.  Electrical engineering friend said that they likely swapped some ground connections around so that when the ignitor draws current it doesn't drop the voltage of the whole system.  Not sure if a homeowner could troubleshoot and solve this one without directions from manufacturer.
Frigidaire... | Answered on Apr 12, 2016
Good Afternoon Friend,
I understand you want to know how to turn on your Frigidaire range, model# FGF378AC. First, you will need to make sure you have set the clock, by pressing the clock button and then pressing and holding down either the up or down arrows until the correct time displays.
Secondly, you will turn your oven on by pressing the "Bake" button and then pressing and holding down either the up or down arrows until the correct temperature displays. Once you release the up or down arrow, your oven should begin heating to the desired temperature. The control will beep three times, once the temperature has been reached.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jul 01, 2014
You will need to replace the ignition switch assembly. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Frigidaire... | Answered on Nov 13, 2012
sounds normal. most ranges have 2 hr (give or take) burnoff period when it is first used when it burns off any residual chemicals from factory. just make sure you've taken all plastic/packaging and wipe down the interior first.
Frigidaire... | Answered on Feb 19, 2011
From what I can see on the web, all point to a weak "glow ignitor," some says that the glow ignitor can glow and sometimes can even be drawing the correct current but still not hot enough to ignite the gas. Tho one thing I don't understand is how can a ignitor range in price that much... I can find one online for $16 to $50... local appliance part stores wants $70 - $80 for it... and its not refundable...
Frigidaire... | Answered on Jan 12, 2011
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Frigidaire... | Answered on Nov 24, 2010
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Frigidaire... | Answered on Jul 15, 2010
It is possible but you have to know how, top burners will be easier to do then oven, for top burner you will needed push button switch, spark module and electrodes. I never done the oven but it is possible. Have fun.
Frigidaire... | Answered on Mar 02, 2010
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Frigidaire... | Answered on Jan 30, 2010
Frigidaire FGF378AC Gas Kitchen Range Logo
72 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
model fgf326asd gas oven igniter glows
  • Kitchen Ranges
