1st. short click onceon power boton. 2nd. ask a friend/client to send you a FAX. 3rd. if it still dose not work you need to get in to the FAX`s menu and check if it is in the correct settings: DIAL TONE or PULS. 4th. repet 2nd. step.
Take out the cover that covers your recieving paper and look in there!U will c a smallish black handle with a green sticker on,pull it down gentle and push it up untill it clips into place!Good Luck!
The fax machine is trying to print fax recieved copies on the bypass feeder.
Check up the setup menu on the control console.
Fine fax recieve.
You should find a selection for fax recieved in which paper tray.
Check this area, any that have the bypass feeder, de-select it.
Make selections for 8 1/2 x 11 paper in tray one.
your answering machine is probably picking up the calls before the fax try to use a separate number for the fax or just disconnect the answering machine and get someone to send a test fax to see if it works
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
