SOURCE: Insignia LCD HD tv with "No Signal/VGA input"
Your Television need to be reset. Take the back off carefully, locate your picture lamp, somewhere in that area should be your reset button. Your television needs to be powered on, so be very carefull not to touch anything other than the reset button, hold the button in until your TV goes blank, then release and put your cover back on. That's it, your TV should be back to normal. You might have to run your setup again.
I am trying to locate the reset button and can not locate it. What does it look like? I took the back off the tv already, do not know if I have to take more apart.
Thanks
SOURCE: No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
SOURCE: No sound on NON HD channels
Check menu on tv and see if the audio input has any other settings. May have different options for sound processing.
