20 Most Recent
Sony KDL-40XBR4 40 in. LCD HDTV Questions & Answers
Upgraded to Hd and tv started messing up. Double images for first 10 minutes and sometimes tv picture goes off and lines up and down.
Your HDTV is capable of up to 1080P resolution. SDTV (standard def) signals are 480i; EDTV (enhanced def) is 480P; HDTV are 720P, (there is no 720i) 1080i and 1080P. Generally, those modes ending in "P" look better than those ending in "i". 1080i is the highest possible for broadcast TV, but BluRay disks and Directv have 1080P display capabilities. The double picture you're describing sounds like the TV is set to display only standard or enhanced def signals while the Dish Network box is supplying it with HD signals. You should locate the control for the TV's resolution and make sure it is set to "1080P" and then set the output of your Dish Network set top box to the highest output it offers. Do the same for your BluRay player and any other devices, too. Once set correctly, you should have a great picture once again. I hope this helps & good luck!
13 blinks on standby light
If you can post a few pictures of the boards in the unit to our forum at:
http://www.ccl-la.com/forum/index.php Our techs will look over the boards and offer information to guide you in the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Broken, Cracked screen on my
Price
4,003.02
Not Available for Backorder There is a credit for the return of a useable core; but since yours is broken it probably would not be available...
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
There is no red in the picture.
yes,, call the company vendor,, they'll assist you,, sont let any local vendor operate your t.v,, trust only qualified personnal only
Sony kdl-40xbr lcd tv.. turns on for a second then
I am pretty sure this is a Back Light failure or a bad Ballast. If it is the only fix is to replace the LCD Panel. I would contact Sony at 1800-222-Sony and see if the could help you with repairs and also to get a Factory Service Facility near you to confirm the problem.
Hope this helps,
Skyassoc
My tv turn red and blink 13 time
Hi ,
I had same problem my TV. Replaced IC8002 on the 'D' board.
This is what we did:
1.Bought 2 x MCZ3001D from WES components in Ashfield Sydney Australia for $11.20 (each).
2.Friend had an 18 pin machine spun socket (not the crappy ones on EBAY).
3.Took back off TV
4.Put the 'D' board in service position
5.Noted which way IC8002 chip sat (Where position 1 is), also noted which 2 legs are not soldered.
6.Cut
the black plastic that was covering this chip underneath (where D board
screws into) as this is easier than removing the 'D' board.
7.De-soldered the IC8002 chip with a proper de-soldering iron. These are expensive though.
8.Soldered in the 18 pin socket.
9. Set the chip into the socket.
10.Tested TV, worked fine.
11. Put it all back together, plugged in Tivo, DVD etc etc etc and all bloody good stuff.
12.
I now also have a spare MCZ3001D which is taped to the back of the TV
for future replacement, which is now easier since its now in a socket.
Double picture at star up
if you have cable telivison try unpluging the cable from wall and tv the replugging it. make sure the connections are secure and also make sure the cable is plugged in straight. or your cable might be bad.
Problem with Sony KDL-46VL160 46 in. HDTV TV
The problem in most of the case are:
1. Interference from a defective fluorescent lamp at your room sending signals to the infrared receiver of the TV.
2. Defective infrared receiver itself that sending noisy control signals to the CPU.
3. Defective manual control withes it has leakage.
4. Water damaged control switch PC board.
10/30/2017 1:46:11 AM •
Sony KDL...
Answered
on Oct 30, 2017
