20 Most Recent Insignia 32" 720p Flat-Panel LCD HDTV Questions & Answers
suggest that you take it to a repair shop for an estimate.could cost more to fix than a new one would .
Insignia 32"... | Answered on Feb 29, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Insignia 32"... | Answered on Jul 30, 2015
correction your model must be : NS-32L430A11
its from 2007 or 2008
here full specs for your set
http://www.insigniaproducts.com/products/televisions/NS-32L430A11.html
thnaks
http://www.bostonrecycling.net/
Insignia 32"... | Answered on Oct 09, 2014
You probably need to change some settings on the TV. Make sure you push the remote's "ASPECT" button and cycle through those choices. Then you may want to go into the settings and find an auto-adjust. Also, turn off any and all "LETTERBOX" Settings.
Insignia 32"... | Answered on Jun 10, 2014
It sounds that the white balance adjustment is misaligned. You have to enter its service mode to re-adjust this. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Without any knowledge in electronics, nobody cant do this adjustment correctly. Enter the service mode, if you're confident.
Insignia 32"... | Answered on Oct 28, 2013
what are you using on the HDMI cable. you may need to change the setting on that and not the tv. or you have the tv stuck in Zoom. if it is stuck in Zoom you will need to rest the tv back to factory setting.
Insignia 32"... | Answered on Sep 16, 2013
Look at the side where the dvd player to see if it has a small pin hole for inserting a paper clip to eject the disk, if it does not have one then the TV and the DVD transport will have to be disassmbled to get the DVD out. It will not be an easy job so you may want to leave it to the pro to do it.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Insignia 32"... | Answered on Aug 28, 2013
after searching around on both remotes for me...im with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Insignia 32"... | Answered on Aug 14, 2013
please check touch key board i think it is defect
thanks lal electronics
Insignia 32"... | Answered on Jul 16, 2013
When you plug in the set, does the standby light come on? Most likely you are dealing with either a failed power supply or main board. I would start with checked the power supply for bulged capacitors.
Insignia 32"... | Answered on Dec 16, 2012
Insignia 32" 720p Flat-Panel LCD HDTV Logo
130 questions posted
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
lcd television wont turn
  • Televison & Video
