20 Most Recent
Insignia 42" LCD Flat-Panel HDTV Questions & Answers
Insignia TV won't pick up 1080p from Blu Ray
hi there, you did not mention what you are actually watching on the bluray player, i.e is it 720p or 1080p ?. Also, how do you know it is actually 1080p from your cable box ?. And what is the model number of your TV ?.
Last night the tv was fine i turned it on this
Unplug 20 minutes. Make sure there is adequate ventilation around the set.
Try with the original manufacturer remote to view setup menu.
Power outages come at night. This sometimes resets the TV and other devices. .
The red off light is blinking, and it won't turn on.
I would unplug it, give it a day to drain off the capacitors and then plug it in again. Maybe it will g back to normal. Sounds like the ten or 13 blink "death" code though. Plug it in or turn it on and count the number of blinks. I don't know the website, but do a search for the explanation chart. each blink 1-10 or 1-13 tells you what the problem is. If you are very handy, you can replace the board that's causing your problem.
Insignia manual instruction
It is the the fault with the TV itself. What can you do by getting its user manual? Your TV need a through checkup. Contact any service technician. anyway, if you want to get its user manual, try this link.
http://www.retrevo.com/
The manual will be in PDF format.
Electro help
