HP Deskjet D2360 InkJet Printer Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The printer is turned on and it just says offline on the printer status
mukhtar21 shaikh
Level 3:
President:
  • HP Master 2,022 Answers
  • Posted on Feb 20, 2010
mukhtar21 shaikh
HP Master
Level 3:
President:
Answers
2022
Questions
Helped
669350
Points
5817
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
How to Turn Brother 5890cn, 3070cw, 2170w, 9340cdw and j825dw Printer Offline to Online?
The obvious cause of brother printer saying its offline is because it is not set as the default printer on your computer. You can easily change the status of Brother MFC 5890 CN printer offline to online. Under the devices section in your computer check, if it is listed as devices. You must re install the driver from the website. In case, you need to use the Brother Printer offline. Right click on the icon of Brother Printer machine. Then, see what's printing and change it to offline.
https://connectmyprinter.com/how-to-fix-brother-printer-offline-error/
My document is always on pending status when I CLICK PRINT. i NOTICED THAT THE PRINTER STATUS IS OFFLINE
well the printer never lies to you on that .
NO connection told is this USB or lame wifi.(no)
no printer made lies , offline means printer is turned offline or it is failing and turn itself offline.
next is the manual on the printer, read page marked
how to print a self test page.
read the manual first, 15,000 printers no , no 2 the same
thus he magic of manuals
hp page found
https://support.hp.com/us-en/product/hp-psc-1310-all-in-one-printer-series/360489/manuals
page 37. found this in 1min work.
http://h10032.www1.hp.com/ctg/Manual/c00141855.pdf
The self test page must be good or printing will fail.
2004 printers, ive never seen one ever last this long
and has no wifi.
just USB.
RIP 2004 printers. cheap.
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
11helpful
2answers
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
1helpful
Status seen as offline .HP 1400 series
If the printer status is offline it means that you are either A) not connected to the printer by USB/Serial/Parallel B) Connected to the same network as the network printer or C) The printer is not turned on with the approriate connection plugged into the printer/computer.
1helpful
2answers
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
1helpful
Printer status always offline
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
k24674
Grand Canyon Tech
Grand Canyon Tech
