20 Most Recent HP DeskJet 1220c InkJet Printer Questions & Answers
6answers
1220c driver for windows 7
HP 1220c driver for Win 7 is nit working, need help
7/22/2021 4:26:09 AM • HP DeskJet 1220c... • Answered on Jul 22, 2021
Printer won't turn on.
Common problem with this particular Printer is a Bad Power Supply,needs to be replaced,its nothing related to the cleaning you did.you have Order a new power supply Board,open the back cover of printer and Install it.
4/10/2019 11:27:56 AM • HP DeskJet 1220c... • Answered on Apr 10, 2019
Hp dj 1220c printer driver refused to install on
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup https://123hp.co/hp-deskjet-printer-models
4/10/2018 4:50:29 PM • HP DeskJet 1220c... • Answered on Apr 10, 2018
3answers
Please check the link below for the HP driver downloads:
HP 1220 deskjet
2/16/2017 4:15:43 AM • HP DeskJet 1220c... • Answered on Feb 16, 2017
2answers
DREVER FOR HP 1220C
You can download your HP Deskjet 1220C driver from this link selecting your operating system.
Hope this helps.
2/16/2017 4:09:01 AM • HP DeskJet 1220c... • Answered on Feb 16, 2017
My printer 1220c power button when turned on, it refuses to turn off and it displays usb not regnoised
You have a defective printer or the software in your PC is corrupted, reload the printer software, unplug the printer for 5 minutes and see if it works, if not just replace it, the cost to repair can be more than a new printer.
8/11/2016 7:55:13 PM • HP DeskJet 1220c... • Answered on Aug 11, 2016
2answers
I have a 64-bit laptop operating in Windows Home
download compatible for my laptop to use my hp deskjet
7/29/2016 12:51:06 AM • HP DeskJet 1220c... • Answered on Jul 29, 2016
Flashing Orange light will not stop printer will not print
THIS IS A CARTRIDGE OR PAPER JAM ERROR.CHECK FOR ANY PAPER STUCK IN THE PRINTER,ALSO TRY REPLACING INK CARTRIDGES
3/16/2016 1:59:46 AM • HP DeskJet 1220c... • Answered on Mar 16, 2016
0answers
Can't connect iPhone 5s and hp 1220c
Sir/Madam iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue: Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch. Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network Unexpected Wi-Fi signal strength or disconnects Inability to access the Internet Not automatically connecting to WiFi when expected Follow these steps to troubleshoot the above issues: 1.Be sure you're in range of your Wi-Fi router (access point). 2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps. 1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance. 2.Restart your iOS device. 3.Tap Settings WiFi and locate the WiFi network to which you're connected. 4.Tap and Forget this Network. 5.Try to connect to your desired Wi-Fi network. Note: You may need to enter your Wi-Fi password again if your network requires one. 6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service. 7.Update your deviceto the latest version of software. 8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility. If the issue is still unresolved Follow the steps below for the issue you're experiencing. Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network. Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device. See recommended settings forconfiguring your Wi-Fi router for use with iOS devices. Notes 1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN. 2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step. 3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks. If You Still Haveing Problem then Visit official Below Apple Website URL Link: http://support.apple.com/kb/ts1398 Or In case you still having HP Printer Issue Then Follow Us On: HP Printer Support
2/13/2014 12:11:02 PM • HP DeskJet 1220c... • Answered on Feb 13, 2014
Fault 41
In most cases unseating and reseating the cartridge in the unit to dislodge residue from the cartridge contacts can resolve the problem. If this does not immediately resolve the problem, continue the reseating process up to five times. Follow the instructions below. Unseating and reseating the cartridge Turn the unit on and open the lid or top cover. Remove the cartridges. Re-insert the cartridges. Close the unit's lid or top cover. Cycle the power to the device by turning the printer off for a few seconds. Turn the printer back on. Print a test page. If this does not solve the problem, proceed to the next section. Wiping the cartridge contacts Turn the unit on and open the lid or top cover. Remove the cartridges. Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom (see Figure 2). The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom (see Figure 3). Re-insert the cartridges and close the printer's top cover. Print a test page. If the problem persists, perform a hard reset as described in the next section. Performing a hard reset on the unit When the printing unit detects an issue with the cartridge, a software flag is set inside the device. This flag may not reset until performing a hard reset on the device Verify that the unit is switched on. Open printer and remove both cartridges. Unplug the power cord from the printer. Wait 30 seconds. Plug the power cord back into the printer. Open the top cover and reinsert both cartridges. Turn the unit on. Print a test page. If the problem persists, the cartridge should be replaced.
2/10/2014 9:27:52 AM • HP DeskJet 1220c... • Answered on Feb 10, 2014
Have a HP Deskjet 1220c Printer Model C2693A, on light comes on for about 3 seconds, then nothing . . . could this be a power board problem?
its the back cover,if its not at lock position,your printer wont com on
4/2/2013 1:39:54 PM • HP DeskJet 1220c... • Answered on Apr 02, 2013
Printer not on
check the at the back of the printer where you plug in the power cable to see if its loose,and also check you power outlet from the wall,change another plug if possible to know what you dealing with.also make sure that the back cover where paper passes from onside is locked to home possition or else your printer will not turn on if its at unlock position,hope it helps
4/2/2013 1:35:49 PM • HP DeskJet 1220c... • Answered on Apr 02, 2013
Hp deskjet d1320 yellow light keeps blinking
Thank you for suggesting that the cartridge might be bad. I almost got rid of my deskjet D1320 because it was blinking continuously and I could not figure out why. I tried everything from new driver to looking for a paper jam and nothing worked until I tried your suggestion. I tried each of the cartridge separately to find out that the black cartridge was making the light blink but not the color on. I replaced the black cartridge and the printer is fine now
1/6/2013 5:19:24 PM • HP DeskJet 1220c... • Answered on Jan 06, 2013
HP DeskJet 1220c InkJet Printer Logo
189 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp deskjet 1220c printer prints only 1
  • Office Equipment & Supplies
