20 Most Recent HP Deskjet D2360 InkJet Printer Questions & Answers
Click on the link below to download the driver for the HP Deskjet D2360 for the windows vista operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-47558-1&lc=en&dlc=en&cc=us&product=1100995&os=2093&lang=en
Click on the link below to download the driver for HP Deskjet D2360 for the windows XP operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-41763-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=1100995
Click on the link below to download the driver for the HP Deskjet D2360 for the windows 2000 operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-41763-1&lc=en&dlc=en&cc=us&lang=en&os=181&product=1100995
HP Deskjet D2360... | Answered on Feb 06, 2019
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
HP Deskjet D2360... | Answered on Oct 13, 2018
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
log onto HP website look for dowload type the description of the product and there you can dowlnload your driver.
HP Deskjet D2360... | Answered on Oct 31, 2017
Lost my installer. i reformat my computer. how cn i install the printer without the installer HP Deskjet D2360
plz check the hp website
HP Deskjet D2360... | Answered on May 09, 2017
First, try running the installation as Administrator. Right click on the executable and select Run as Administrator. If that doesn't work, go to that registry entry and make sure that System and Administrators have Full Permissions.
HP Deskjet D2360... | Answered on Mar 26, 2017
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
HP Deskjet D2360... | Answered on Mar 06, 2016
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
HP Deskjet D2360... | Answered on Dec 17, 2014
Reinstall cartridges slowly so printer can detect it
HP Deskjet D2360... | Answered on Jun 23, 2014
go to manufacture web site download drivers for free
HP Deskjet D2360... | Answered on Dec 18, 2013
1. check that ur usb cable is working by changing with a new one
2. remove d black cartridge n close door/lid
3. if no response, do same wit color cartridge
4. insert into another usb port on computer
5. if no response still, remove cartridges and clean printer interface with a cotton wool and methylated spirit
HP Deskjet D2360... | Answered on Oct 14, 2013
you will have to dismantle the entire machine to remove the axle that holds the cradle in place , and remove the cradle and then you would be able to fit the belt back
HP Deskjet D2360... | Answered on Oct 11, 2013
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
HP Deskjet D2360... | Answered on Oct 10, 2013
HP Deskjet D2360 InkJet Printer Logo
333 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
install
  • Office Equipment & Supplies
