20 Most Recent HP DeskJet F380 All-In-One Printer Questions & Answers
  1. Go to HP website. http://welcome.hp.com/country/us/en/support.html
  2. Insert model number.
  3. Download driver.
  4. Double click downloaded file. This will install the driver and software.
HP DeskJet F380... | Answered 17 hours ago
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
HP DeskJet F380... | Answered on Sep 12, 2018
Next page gives support for HP F380, Windows 7 32-bit:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4062&lc=en&dlc=en&cc=us&product=1128296&lang=en
For other Operating Systems for the F380, go to next link and select the required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&lang=en&cc=us
HP DeskJet F380... | Answered on Feb 16, 2018
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
HP DeskJet F380... | Answered on Feb 15, 2018
I lost the CD installer of my HP Deskjet F380, how I can install it?
i was in HP tech support supporting AIO printer models, Just click on the link u will get a popup window to download the Driver for ur Printer.
http://snipurl.com/f380_driver_xp
Is it a legit HP ink cartridge? I have had a few knockoffs fail to be recognized in my printer. Seems like the printer companies are getting wise to the knock off brands
HP DeskJet F380... | Answered on Feb 12, 2018
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
HP DeskJet F380... | Answered on Feb 01, 2018
Might be scanner drivers corrupted, Reinstall the Scanner drivers again. Most probably this will work greatly You can try this no (877-690-9305) for the solution. Support For Hp Printer
HP DeskJet F380... | Answered on Jan 30, 2018
Recognition of cartridges depends on several issues. Check and clean the metal contact points on the printer cartridge slot. Use rubbing alcohol on a q-tip and pat dry. Do the same on the ink cart. Any oil/film on the contacts can interfere with the communication network of the printer. Sometimes, printers just reject cartridges, mainly if you use off brand products. Naturally HP wants you to use their cartridges! Other than that, you must use HP Software updates for the computer and also, update each HP Printers FIRMWARE. Lots of folks forget that!
HP DeskJet F380... | Answered on Jan 12, 2018
if you are using word to type the address use the tool bar to center it on the page
then when you go to print , check the preview to see where it will be printed
set the printer properties to envelope and use any old envelope to see where it prints
HP DeskJet F380... | Answered on Nov 15, 2017
check out the HP website for support
HP Deskjet 1050 All in One Printer J410a Troubleshooting
HP DeskJet F380... | Answered on Nov 12, 2017
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
HP DeskJet F380... | Answered on Apr 27, 2017
Listen, so you are a tad clutzy. Swallow your pride and continue to let your friend help you out. U would do it for him, wouldn't you?
HP DeskJet F380... | Answered on Apr 25, 2017
The default printer is set to be "file". Here's what you must do:
- Go to printers dialogue box and right click on your printer name and selectd "Set s default printer"
 - Right click on printers name and chose Properties. then look for a check box saing something like "print to file" and unchek it.
This sould resolve the problem.
Best regards
HP DeskJet F380... | Answered on Mar 17, 2017
there is a sensor which detects if there is a paper jam in the printer.that sensor is bit moved from its orignal position so it is continuously detecting the paper jam in your case.
HP DeskJet F380... | Answered on Mar 10, 2017
Below are the HP Printer Models and Price
HP Deskjet F4185 Printer Price - Rs.3,800
HP Officejet 4355 Printer Price - Rs.5,400
HP LaserJet P1007 Printer Price - Rs.5,590
HP Deskjet F4100 All-in-One Printer Price - Rs.4,999
Try the Just Dial #6999 9999 ( with code 080 ) to know the available HP Authorized Centers near Hennur Road.
*Rate this Answer with Thumbs Up if satisfactory
HP DeskJet F380... | Answered on Nov 14, 2016
HP DeskJet F380 All-In-One Printer Logo
2,551 questions posted
Clive
Clive
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
cannot connect wireless hp 3520 printer
  • Office Equipment & Supplies
