Freezers Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge door sagged and needs adjusting.
The Fridge door is sagging and catching on bottom frame. It needs adjusting but I can't see how to do this or a solution in the manual.
Victor Nwachukwu
Level 2:
Guru:
  • Expert 157 Answers
  • Posted on Feb 20, 2010
Victor Nwachukwu
Expert
Level 2:
Guru:
Answers
157
Questions
0
Helped
39534
Points
347
The screw holding the door is not well tightening.
2helpful
2answers
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Model 253.28432807. Household power went off today for a couple of hours. Restored. Freezer has power but display is illegible. Up arrow does nothing. Down arrow changes display but display is erratic and...
Electronic components are very sensitive to voltage surges, spikes or sags.
Voltage is not delivered at a constant 120 volts. With alternating current, the voltage rises and falls in a predetermined rhythm. The voltage oscillates from 0 to a peak voltage of 169 volts. Most appliances and electronics used in the United States are designed to be powered by this form of generated electricity.
During a power surge, the voltage exceeds the peak voltage of 169 volts.
A spike in voltage can be harmful to appliances and electrical devices in your home. An increase in voltage above an appliance's normal operating voltage can cause an arc of electrical current within the appliance. The heat generated in the arc causes damage to the electronic circuit boards and other electrical components.
(Smaller, repeated power surges may slowly damage your electronic equipment, over time too.)
Voltage sags, a.k.a voltage dips or brownouts, is another form of electrical disturbance that can damage appliances as well.
The bottom line, power surges, spikes, and sags can vary in duration and magnitude; and can damage electrical equipment ranging from stereos to computers to any household appliance that uses chip board circuitry sensitive enough to "blow" due to over or under-energizing it.
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 • Freezers
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 • Freezers
I have a Defy C380, its a 2 door fridge with the freezer compartment at the bottom. The freezer compartment makes ice after about 12 hrs, I need to efrost the freezer weekly. There are gaps between the...
Door adjustments instructions should be found in your users manual. No manual, follow this link.
http://www.manualsonline.com/
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 31, 2017 • Freezers
Horizontal fridge freezer - Freezer over-heating
The door frame has a heater to stop ice forming around frame. This is normal. You don't notice it when freezer is cold. The freezer should start working again.
Nov 01, 2009 • Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 • Freezers
1helpful
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
Fridge Freezer
The hinges at the top and bottom have screws. These may be hidden under a plastic cover which can be pried off. The water and wiring, will have disconnects at the bottom of door. Take the top ones off and lift the door up.
Apr 22, 2008 • Freezers
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
