20 Most Recent Kelvinator 12 cu. ft. / 340 liter Chest Freezer KDC-47 Questions & Answers
Fixya is unable to suggest sources for a Kelvinator defrost element.
Kelvinator 12... | Answered on Mar 05, 2018
call in a refrigeration repairman it probably needs freon added to system .
Kelvinator 12... | Answered on Aug 28, 2016
If it makes a clicking sound every few minutes and is not cooling.... Replace the start device on the compressor Kelvinator Freezer Start Relay 216594300 or possibly a URCO410.
Kelvinator 12... | Answered on Aug 01, 2016
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Kelvinator 12... | Answered on Mar 04, 2015
you cannot fix a punctured evaporator coil. The cost is not economical and the repair is unreliable. best consider another fridge.
Kelvinator 12... | Answered on Mar 03, 2015
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Kelvinator 12... | Answered on Jan 06, 2014
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Kelvinator 12... | Answered on Jun 04, 2013
try jumping out the thermostat assuming the compressor is not trying to start.
Kelvinator 12... | Answered on Mar 17, 2012
HI you need a new thermostat, the thermostat is sticking. Change it out will fix your problem
Sean
Kelvinator 12... | Answered on Mar 28, 2011
This was the best photo I could get. I hope is is at all useful. Cheers!
Kelvinator 12... | Answered on Jan 01, 2011
Left = warm Right = cold
Kelvinator 12... | Answered on Dec 26, 2010
Freezers Logo
60 questions posted
Popular Products
Top Kelvinator Freezers Experts
George Merkley
George Merkley
ray gallant
ray gallant
knot
knot
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kelvinator Freezers
  • Kelvinator Freezers
Most Popular Question
level domestic kelvinator fridge floor
  • Freezers
