20 Most Recent True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Questions & Answers
2answers
I NEED A wiring DIAGRAM FOR a T-72 F TRUE FREEZER
I need A wire diagram for a freezer mo.49f
10/19/2023 7:52:03 PM • True 72 cu. ft.... • Answered on Oct 19, 2023
P-1 code
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
12/30/2021 4:41:23 PM • True 72 cu. ft.... • Answered on Dec 30, 2021
My freezer build up ice
sounds like you are getting low on freon do you have freon gaddges to check it if not i can rent you some useing paypal
2/6/2021 11:02:45 PM • True 72 cu. ft.... • Answered on Feb 06, 2021
Heater elements not coming on
Is it the defrost heater element? There are several possibilities. Check defrost timer operation and output, check overheat limit klixon (attached to evaporator), check heater continuity.
1/12/2021 1:36:26 AM • True 72 cu. ft.... • Answered on Jan 12, 2021
I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
1/10/2021 7:05:08 AM • True 72 cu. ft.... • Answered on Jan 10, 2021
Freezer door is very hot to the touch on the outside
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
11/11/2015 11:35:35 PM • True 72 cu. ft.... • Answered on Nov 11, 2015
2answers
Freezer will not cool below 28 degrees . head
Head pressure should be around 250#.
Be sure condenser is clean. Use a good foaming cleaner.
3/2/2015 5:11:54 PM • True 72 cu. ft.... • Answered on Mar 02, 2015
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
2/23/2014 12:44:13 PM • True 72 cu. ft.... • Answered on Feb 23, 2014
0answers
Can a True Commercial T-72 refrigerator be converted to a Freezer
Would take more time and money than buying a T-72F freezer.
10/24/2013 11:46:56 AM • True 72 cu. ft.... • Answered on Oct 24, 2013
0answers
0answers
Where is the thermostat 0n theTRUE 72 freezer
right side of the evap. coil housing inside.
4/18/2013 1:57:31 AM • True 72 cu. ft.... • Answered on Apr 18, 2013
True T72F defrost timer and lights not working?
You have done good work here young man. There is a relay or switch that is keeping the signal for being processed. I had the same similar problem with mine. At least your compressor is ok. Are you sure timer is wired back right.
2/14/2013 2:46:27 PM • True 72 cu. ft.... • Answered on Feb 14, 2013
Had a fire and need to rewire
Here is a PDF of Techinical information for all models of the True T-72F I will be here later should you have questions, Thanks Sea Breeze
2/9/2013 6:03:47 PM • True 72 cu. ft.... • Answered on Feb 09, 2013
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
5/16/2012 9:02:22 PM • True 72 cu. ft.... • Answered on May 16, 2012
How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
4/6/2012 6:02:49 PM • True 72 cu. ft.... • Answered on Apr 06, 2012
0answers
True gdm12 evap fan runs all the time evev with
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
10/23/2011 7:20:35 PM • True 72 cu. ft.... • Answered on Oct 23, 2011
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
65 questions posted
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
View Most Popular
True Freezers
  • True Freezers
Most Popular Question
  • Freezers
