20 Most Recent Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Questions & Answers
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Danby 3.6 cu.... | Answered on Feb 08, 2016
Hello;
My name is Peter. I am a retired field service refrigeration technician.
In to your question: No.
The problem with these units is that the covers are very flexible. I am to manually bent the cover back in shape.
Before you do that, Make sure the gasket is not iced up some where. Also, make sure the gasket is even in height. Your can buy a cover gasket for your unit, but if the cover is bent out of shape you are back to the same problem.
Danby 3.6 cu.... | Answered on Feb 15, 2015
On a chest freezer , the coils are located inside the walls of the freezer . The heat normally felt on the outside is the condensor coils inside the wall. The coldness felt on the inside is from the evaporator coils also inside the freezer wall .If the inside of the freezer has over 1/2 inch of frost , then defrosting may work . If NO frost on the inside , possible leak in the coils which are not accessable . Only solution is to replace the freezer . Anyone can buy refrigerant 134a which is what your freezer uses .
Danby 3.6 cu.... | Answered on Dec 05, 2014
These power lights are usually of the neon lamp type, and they typically do not last a long time, especially when they are powered on 24/7. They typically fail by flickering at first, then, eventually, they just go out. If you feel confident as a "do it yourselfer", you can often replace this lamp for only a few bucks, but it does require disassembly of the control unit. Otherwise, I'd just leave it alone. If you're concerned about food loss, I'd invest in a freezer alarm. The lamp has no bearing on the operation of the compressor unit. On, flickering or out completely, the freezer will still operate normally.
Danby 3.6 cu.... | Answered on Jun 06, 2014
Usually about 500 to 700 $ if it's the compressor the thermostat is way cheaper and there's no compressor thermostat it's one or the other
Danby 3.6 cu.... | Answered on Dec 12, 2013
Try unplugging the freezer for 10 minutes to reset the cycle.
Danby 3.6 cu.... | Answered on Oct 18, 2013
7 is the coldest. Defrosting is set up at the factory. It may not be a problem. If it doesn't come out after say 2 hours, then the defrost cycle is faulty.
Danby 3.6 cu.... | Answered on Feb 06, 2013
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
104 questions posted
Top Danby Freezers Experts
Dennis Boxerman
Bruce Denton
kfinlay1969
Level 1 Expert
Are you a Danby Freezer Expert? Answer questions, earn points and help others
View Most Popular
Danby Freezers
  • Danby Freezers
Most Popular Question
temperature control
  • Freezers
