20 Most Recent
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 13541 Questions & Answers
Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Freezer reads off on display
Not sure if its the same for all Kenmore freezer models but this may indicate it is in demo mode. To remove this press the up or down arrow three times as fast as possible (within 2 seconds). This will start the compressor, I hope this helps.
Display reads off
There may be a child lock enabled, refer to the owner's manual to disable this feature, otherwise check the troubleshooting section of the manual.
HI i just bought a
No, it's supposed to be hot on its outside: just make sure the airflow around it is good, the compressor and the radiator at the back are clean and the power plug has a good grounding and a proper fuse and all will be OK.
In the worst case scenario you have a malfunctioning defrost resistance that is constantly on and when it will fry it will take the compressor with it, killing the freezer. But only it, the rest of the house and yourself are perfectly fine. If you want to prevent that you will have to dismantle the freezer and disconnect the resistance - without it the ice buildup inside it will be much faster so you will have to stop the freezer for deicing sooner than normal.
Can I put my freezer
YES you can i would put down one of those plastic thing though that you use at the office and roll the chair around on,first to protect the carpet from potential drips and rust stains
Has power but does not freeze
About the only things that can be replaced on a chest style freezer are the thermostat, and the starting device for the compressor. if you know where the control is then thump it fairly hard to see if the unit comes on. If unit comes on then you need to replace the thermostat. (control and thermostat are same thing). now if it has the digital display on the door of the freezer do not thump it. Only the newer freezers have those though. Hope this helps
Where is the drain plug
Most freezer do not have a drain plug...it is very possible that you do not have one on yours...
The best way to get the water out is to siphon with a small hose till there is not much left .... then wipe out the rest with a rag....
Tipping the freezer to one corner will help you siphon more of the water out...
heatman101
