20 Most Recent Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer Questions & Answers
3answers
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
12/24/2019 12:02:23 AM • Kenmore Freezer... • Answered on Dec 24, 2019
Two amber lights are on on my upright kenmore freezer and its not cooling , rocker swith is in the off position . when I turn it to onposition it buzzes loud
Test and fiction is improved for the natural element for the sharing for all joys for people. The choice of the tool and essay writing service reviews is fixed for the enhancement of the goals. The vital path is bifurcated for the offered items for people. the natural way is ousted for the comfort and all enhancement of the research for the true picture and all moves for humans. kids are invited for the attentive pictures for the field.
11/4/2019 5:56:47 PM • Kenmore Freezer... • Answered on Nov 04, 2019
3answers
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
4/26/2017 11:36:27 AM • Kenmore Freezer... • Answered on Apr 26, 2017
My frost free upright freezer is usddenly
Door seals are leaking air into the cabinet.
4/4/2016 10:43:32 AM • Kenmore Freezer... • Answered on Apr 04, 2016
My freezer has power but is not cooling is there a reset
no, need more info, model serial and do you hear anything at all.
3/10/2016 12:00:12 AM • Kenmore Freezer... • Answered on Mar 10, 2016
It chills properly but when fan turns on it makes this squealing sound
Probably needs to be vacuumed and a little oil, if that doesn't help the fan may need to be replaced
10/10/2015 1:04:06 AM • Kenmore Freezer... • Answered on Oct 10, 2015
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
1/27/2015 2:30:17 AM • Kenmore Freezer... • Answered on Jan 27, 2015
Freezer stops working and then over cools to -10
Sounds like the thermostatic control is worn out. Replacing it should fix the problem. Hope this helps. Bob
12/17/2014 3:58:56 AM • Kenmore Freezer... • Answered on Dec 17, 2014
3answers
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
11/26/2014 5:06:32 AM • Kenmore Freezer... • Answered on Nov 26, 2014
Why wont my freezer wont freeze everything else does
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge) Air needs to circulate in both parts (dependent on eachother)
9/21/2014 1:11:09 PM • Kenmore Freezer... • Answered on Sep 21, 2014
check and empty the drain pan, you should be able to gain access by removing the vent grill below the door if there is one. The pan is under the unit somewhere. There is also a drain tube, make sure its not blocked with ice.
9/6/2014 6:29:54 PM • Kenmore Freezer... • Answered on Sep 06, 2014
How do you remove control panel on kenmore #2805 freezer
Is the compressor relay bad?
8/28/2014 9:17:41 PM • Kenmore Freezer... • Answered on Aug 28, 2014
0answers
What tool do I need to remove a kenmore upright freezer door
A Torx bit for a power screwdriver or a Torx wrench size T20 or T15 probably.
8/5/2014 1:40:22 PM • Kenmore Freezer... • Answered on Aug 05, 2014
0answers
Ice cream not freezing hard
Ice cream needs to be at 10 degrees or colder to stay hard. Check your thermostat and move it colder if you need but give it 24 hours to stabilize to the new setting. Another thing you might check are the coils on the outside of your freezer. They will be on the back or underneath your freezer. What you need to look for is to see if there is any lint or dirt that might be built up on the coils. If they are real dirty they need to be cleaned off with a vacuum or an air hose if you have one. The dirt build up keeps the freezer from cooling efficiently and causes it to run warmer than normal. If all of that is clean and boosting the thermostat to a colder setting does not take care of it you might need to call a service tech. Hope this helps.
7/24/2014 5:43:52 PM • Kenmore Freezer... • Answered on Jul 24, 2014
Freezers Logo
295 questions posted
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
chills properly but when fan turns makes
  • Freezers
